Ubuntu 11.04 Server amd64 - 1.24.3 Source Install Guide
MILxDOT
Post by MILxDOT »
INSTALL SERVER OS
Perform a fresh install Ubuntu Server 11.04 amd64 DO NOT install any packages during the initial install other than openssh-server.
GO SUDO AND STAY THERE FOR ENTIRE INSTALLATION
sudo -i
UPDATE SERVER OS
apt-get update; apt-get dist-upgrade
REBOOT
/sbin/shutdown now -r
SET A STATIC IP (optional)
nano /etc/network/interfaces
INSTALL ALL ZONEMINDER PREREQUISITES
apt-get install build-essential subversion git-core checkinstall yasm texi2html libfaac-dev libfaad-dev libmp3lame-dev libsdl1.2-dev libtheora-dev libx11-dev libxvidcore-dev zlib1g-dev build-essential linux-headers-`uname -r` automake perl libnet-ssleay-perl openssl libauthen-pam-perl libpam-runtime libio-pty-perl apache2 php5-mysql libapache2-mod-php5 mysql-server libmysqlclient16-dev libarchive-zip-perl libdate-manip-perl libdevice-serialport-perl libjpeg62 libjpeg62-dev libmime-perl libstdc++6 libwww-perl zlib1g zip unzip patch ntp openssl libpcre3-dev libssl-dev libjpeg-progs libcurl4-gnutls-dev munin munin-node libmime-lite-perl netpbm libbz2-dev sysvinit-utils ffmpeg x264 libx264-dev curl lynx coreutils bc
INSTALL PERL MODULES
perl -MCPAN -e shell
install CPAN
install YAML PHP::Serialization Module::Load X10::ActiveHome
install Sys::Mmap
exit
INSTALL AND CONFIGURE ZONEMINDER
cd /usr/src
svn co http://svn.zoneminder.com/svn/zm/trunk zm
cd zm
./configure --with-webdir=/var/www --with-cgidir=/usr/lib/cgi-bin ZM_DB_HOST=localhost ZM_DB_NAME=zm ZM_DB_USER=zmuser ZM_DB_PASS=zmpass --enable-debug=yes --with-webgroup=www-data --with-webuser=www-data
make
make install
mysql < db/zm_create.sql
mysql
grant select,insert,update,delete on zm.* to 'zmuser'@localhost identified by 'zmpass';
flush privileges;
quit
INSTALL CAMBOZOLA
cd /usr/src
wget http://www.charliemouse.com:8080/code/cambozola/cambozola-latest.tar.gz
tar -xzvf cambozola-latest.tar.gz
cp cambozola-0.92/dist/cambozola.jar /var/www
INSTALL JSCALENDAR
cd /usr/src
wget -O jscalendar-1.0.zip "http://sourceforge.net/projects/jscalendar/files/jscalendar/1.0/jscalendar-1.0.zip/download"
unzip jscalendar-1.0.zip
mkdir /var/www/tools/jscalendar
cp -R jscalendar-1.0/* /var/www/tools/jscalendar
REMOVE EXISTING index.html
rm /var/www/index.html
SET SHARED MEMORY SETTINGS
echo "kernel.shmall = 268435456" >> /etc/sysctl.conf
echo "kernel.shmmax = 268435456" >> /etc/sysctl.conf
CREATE STARTUP SCRIPT
Use nano or vi to create/edit /etc/init.d/zm
nano /etc/init.d/zm  (then paste the following)
#!/bin/sh
# description: Control ZoneMinder as a Service
# chkconfig: 2345 99 99
# Source function library.
#. /etc/rc.d/init.d/functions
prog=ZoneMinder
ZM_PATH_BIN="/usr/local/bin"
command="$ZM_PATH_BIN/zmpkg.pl"
start() {
echo -n "Starting $prog: "
    if ! [ -d /tmp/zm ]; then
        mkdir /tmp/zm
        chown -R www-data:www-data /tmp/zm
    fi
$command start
RETVAL=$?
[ $RETVAL = 0 ] && echo success
[ $RETVAL != 0 ] && echo failure
return $RETVAL
stop() {
echo -n "Stopping $prog: "
$command stop
RETVAL=$?
status() {
result=`$command status`
if [ "$result" = "running" ]; then
echo "ZoneMinder is running"
RETVAL=0
else
echo "ZoneMinder is stopped"
RETVAL=1
fi
case "$1" in
'start')
start
'stop')
stop
'restart')
stop
start
'status')
status
echo "Usage: $0 { start | stop | restart | status }"
RETVAL=1
esac
exit $RETVAL
(then save and exit)
SETUP ZM TO STARTUP AUTOMATICALLY AFTER A REBOOT
nano /etc/rc.local
(paste the following above the exit 0 line):
sleep 20 && /etc/init.d/zm start
SET PERMISSIONS ON STARTUP SCRIPT
chmod 755 /etc/init.d/zm
REBOOT THE SERVER
LOGIN TO ZONEMINDER
Open a web browser and visit http://ipaddressofyourserver
MAKE SURE YOU SET YOUR purgewhenfull filter!
MILxDOT
Post by MILxDOT »
I have tested this build with the new eyezm app on my iphone 4 iOS 4.3.
Works very good!
My thanks to the eyezm developer for a great app!
estranged1977
Re: Ubuntu 11.04 Server amd64 - 1.24.3 Source Install Guide
Post by estranged1977 »
Hi, I installed all the system, it works but Im having troubles with record mode, I have 6 network cams, Dlink-DCS-910 and when I set them to just record the timeline is with blank spaces, it is not recording the entire day, it has a lot of blank spaces, any Idea?
jomimube
Post by jomimube »
Thanks for passing their knowledge.
Fresh install Ubuntu 10.10 on Dell Dimension 3000 Server 32-Bit.
last lines with error
checking for perl module Getopt:: Long ... ok
checking for perl module Time:: HiRes ... ok
checking for perl module Date:: Manip ... ok
checking for perl module LWP:: UserAgent ... ok
checking for perl module PHP:: Serialization ... no
configure: error: zm Requires PHP:: Serialization
CPAN in error is:
cpan [1]> install YAML PHP:: Serialization Module:: Load X10:: ActiveHome
CPAN: Storable loaded ok (v2.20)
Going to read '/ root / .cpan / Metadata'
Warning: Can not install PHP:: Serialization, Do not Know What It Is.
Try the command
i / PHP:: Serialization /
to find objects with matching identifiers.
CPAN: Time:: HiRes loaded ok (v1.9719)
Warning: Can not install Module:: Load, Do not Know What It Is.
Try the command
i / Module:: Load /
Warning: Can not install X10:: ActiveHome, Do not Know What It Is.
Try the command
i / X10:: ActiveHome /
Running install for module 'YAML'
The YAML module isn't available on CPAN.
Either the module Has Not Been yet uploaded to CPAN, or it is
temporary unavailable. Please contact the author to find out
more about the status. Try 'i YAML'.
La próxima generación en este planeta, sera Linux.
martymoose
Post by martymoose »
did you get the 32bit version working
I donated have YOU?
