Page 1 of 1
Dual Card System
Posted: Tue Feb 15, 2011 7:24 pm
by xxMOISESxx
Hi guys,
I was wondering if it's possible to have a System with 2 different cards (Kodicom 4400 and Geovision GV800 16ch each). Is this possible? any hardware requirements or conflicts?.
Thanks in Advance.
Posted: Wed Feb 16, 2011 12:58 am
by timcraig
As long as the Linux kernel has drivers for those cards, they should work.
An issue you might have is the /dev/video[number] mapping is different every time after a system reboot.
If that's the case, you can force the mapping or have the system create symbolic links with names of your choosing (e.g. /dev/geovision0, /dev/kondicom0) using udev rules.
Posted: Wed Feb 16, 2011 7:15 pm
by xxMOISESxx
Thanks Tim.
I'm still not sure if I'll have to do this, but it's good to know that it is possible (as I suspected). I'll be back here for sure if I have to setup the system.
Re: Dual Card System
Posted: Mon Mar 28, 2011 7:07 pm
by mainterpet
ATI Crossfire and Nvidia quad sli. Yes, I would personally get the same card. Both require specific system boards, of course. For example for Nvidia sli should be able to Board. Most of new motherboards support crossfire. With regard to food once you narrow down the Board to purchase, you can go from there.
