having trouble with zoneminder 1.24.2 on ubuntu 10.04 server
I have installed zoneminder running apt-get install zoneminder and it installs correctly. I am able to connect from a wepage to it and setup video0 and video1 but nothing happens. The video screen opens but nothing plays. I am running a wintv-pvr 150 and wintv-pvr-250 card. I know both cards are working fine as i go under dmesg and see them installed with no errors. I also run: dmesg | grep Initialized
[ 10.442558] ivtv0: Initialized card: Hauppauge WinTV PVR-150
[ 11.513321] ivtv1: Initialized card: Hauppauge WinTV PVR-250
under cd /dev i see this.
video0
video1
video24
video25
video32
video33
i then test the video by typing.
cat /dev/video0 > /home/joe/test_captureTEST5000.mpg (this plays back in vlc player fine)
i then test video1.
cat /dev/video1 > /home/joe/test_captureTEST6000.mpg (this one plays back in vlc player fine too.
When i run v412-ctl -T, i get 99% signal on the video0, then i run v4l2-ctl --device=/dev/video1 -T and i get 99% on video1 signal too.
Now i just need help on getting zoneminder to play the video as i setup video0 and video1 in zoneminder and it installed properly.
i installed zoneminder by running. sudo apt-get install zoneminder
also shared memory is setup.
root@ubuntu-test:~# sudo sysctl -p
kernel.shmall = 134217728
kernel.shmmax = 134217728
root@ubuntu-test:~# ipcs -l
------ Shared Memory Limits --------
max number of segments = 4096
max seg size (kbytes) = 131072
max total shared memory (kbytes) = 536870912
min seg size (bytes) = 1
------ Semaphore Limits --------
max number of arrays = 128
max semaphores per array = 250
max semaphores system wide = 32000
max ops per semop call = 32
semaphore max value = 32767
------ Messages: Limits --------
max queues system wide = 713
max size of message (bytes) = 8192
default max size of queue (bytes) = 16384
root@ubuntu-test:~#
SOMEONE PLEASE HELP ME WITH THIS.
thanks
video0
video1
video24
video25
video32
video33
i then test video1.
root@ubuntu-test:~#
thanks
nobody can answer my question?
i tried this and still no luck. http://www.zoneminder.com/wiki/index.ph ... 29_Desktop
here is my apparmor setting status. It shows its loaded.keyboardgnome wrote:Check your AppArmor settings, if there are any; this is a new feature that stumped me before.
apparmor module is loaded.
5 profiles are loaded.
5 profiles are in enforce mode.
/sbin/dhclient3
/usr/lib/NetworkManager/nm-dhcp-client.action
/usr/lib/connman/scripts/dhclient-script
/usr/sbin/mysqld
/usr/sbin/tcpdump
0 profiles are in complain mode.
2 processes have profiles defined.
1 processes are in enforce mode :
/usr/sbin/mysqld (654)
0 processes are in complain mode.
1 processes are unconfined but have a profile defined.
/sbin/dhclient3 (572)
Here is also my signal for video0 and video1.
Tuner:
Name : ivtv TV Tuner
Capabilities : 62.5 kHz multi-standard stereo lang1 lang2
Frequency range : 44.0 MHz - 958.0 MHz
Signal strength/AFC : 99%/0
Current audio mode : stereo
Available subchannels: stereo
root@ubuntu-test:~# v4l2-ctl --device=/dev/video0 -T
Tuner:
Current audio mode : lang1
Available subchannels: mono lang2
root@ubuntu-test:~#
anyone please help me out with getting zoneminder to work.
i figured someone on this forum could help me with my problem but still no answers. 252 views and only 1 reply. I gave alot of information and everything seems well with the setup of zoneminder and ubuntu 10.04 with wintv-pvr 150 and 250 cards. So not sure why zoneminder wont show the videos.
-----i found this on a forum
Once you have configured your first device, you can test that there are no permission problems by starting zmc using the www-data user:
sudo su www-data -c 'zmc --device /dev/video1'
If this is capturing, it should not return until you hit Ctrl-C. If it returns immediately, you have a problem.
***I run this command on video0 and video1 and it returns immediately to a prompt and they suggested if it does, then there is a problem.
These forums seem to be pretty dead actually. I haven't got many answers myself.
I've some into similar problem with my camera's. I would first check /var/log/messages and see what type of error's you are getting.
Type
tail /var/log/messages
Most likely your getting a shared memory error. Most of the problems I had I was able to resolve by looking in /var/log/messages. Some of them I just took the error and pasted it into Google and found and answer somewhere.
It ended up being the rights for apache. I gave apache the necessary rights and it started to work.
I ran into lots of different problems but that's a common one I've worked with.
Type
here is my log messages and i dont really see any errors.Yamanipanuchi wrote:These forums seem to be pretty dead actually. I haven't got many answers myself.
Type
Most likely you getting a shared memory error. Most of the problems I had I was able to resolve by looking in /var/log/messages. Some of them I just took the error and pasted it into Google and found and answer somewhere.
It ended up being the right for apache. I gave apache the necessary rights and it started to work.
root@ubuntu-test:~# tail /var/log/messages
Nov 9 06:28:35 ubuntu-test zmdc[12921]: INF ['zmc -d /dev/video1' started at 10 /11/09 06:28:35]
Nov 9 06:28:35 ubuntu-test zmc_dvideo1[12921]: INF [Debug Level = 0, Debug Log = <none>]
Nov 9 06:28:35 ubuntu-test zmc_dvideo1[12921]: INF [Starting Capture]
Nov 9 06:28:35 ubuntu-test zmc_dvideo1[12921]: INF [Got signal 6 (Aborted), exi ting and forcing backtrace]
Nov 9 06:33:42 ubuntu-test zmdc[12409]: INF [Starting pending process, zmc -d / dev/video0]
Nov 9 06:33:42 ubuntu-test zmdc[12409]: INF ['zmc -d /dev/video0' starting at 1 0/11/09 06:33:42, pid = 12933]
Nov 9 06:33:42 ubuntu-test zmdc[12933]: INF ['zmc -d /dev/video0' started at 10 /11/09 06:33:42]
Nov 9 06:33:42 ubuntu-test zmc_dvideo0[12933]: INF [Debug Level = 0, Debug Log = <none>]
Nov 9 06:33:42 ubuntu-test zmc_dvideo0[12933]: INF [Starting Capture]
Nov 9 06:33:42 ubuntu-test zmc_dvideo0[12933]: INF [Got signal 6 (Aborted), exi ting and forcing backtrace]
root@ubuntu-test:~#
dmb2002man wrote:here is my log messages and i dont really see any errors.Yamanipanuchi wrote:These forums seem to be pretty dead actually. I haven't got many answers myself.
Type
root@ubuntu-test:~#
root@ubuntu-test:~# zmu -d /dev/video0 -q -v
Error, failed to query crop capabilities /dev/video0: Invalid argument
root@ubuntu-test:~# v4lctl -c /dev/video0 list
attribute | type | current | default | comment
norm | choice | NTSC-M | NTSC | NTSC NTSC-M NTSC-M-JP NTSC-M-KR NTSC-443 PAL PAL-BG PAL-H PAL-I PAL-DK PAL-M PAL-N PAL-Nc PAL-60 SECAM SECAM-B
input | choice | Composi | Tuner 1 | Tuner 1 S-Video 1 Composite 1 S-Video 2 Composite 2
audio mode | choice | lang1 | mono | mono stereo lang1 lang2
bright | int | 128 | 128 | range is 0 => 255
contrast | int | 64 | 64 | range is 0 => 127
color | int | 64 | 64 | range is 0 => 127
hue | int | 0 | 0 | range is -128 => 127
volume | int | 60928 | 60928 | range is 0 => 65535
Balance | int | 32768 | 32768 | range is 0 => 65535
Bass | int | 32768 | 32768 | range is 0 => 65535
Treble | int | 32768 | 32768 | range is 0 => 65535
mute | bool | off | off |
root@ubuntu-test:~# cd /tmp
I am getting the same problem, same symptoms as the OP. After turning on debug output, I found the following error in zm_debug.log:
11/09/10 15:51:53.160832 zmc_dvideo1[13803].DB3-zm_zone.cpp/796 [Got coordinate 0,239 from polygon string]
11/09/10 15:51:53.160880 zmc_dvideo1[13803].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
11/09/10 15:51:53.160925 zmc_dvideo1[13803].DB1-zm_zone.cpp/50 [Initialised zone 1/All - 1 - 320x240 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:2304, MxAP:57600, FB:3x3, MnFP:2304, MxFP:57600, MnBS:1536, MxBS:0, MnB:1, MxB:0, OF: 0]
11/09/10 15:51:53.171572 zmc_dvideo1[13803].DB1-zm_monitor.cpp/1814 [Loaded monitor 1(Monitor-1), 1 zones]
11/09/10 15:51:53.171640 zmc_dvideo1[13803].INF-zmc.cpp/188 [Starting Capture]
11/09/10 15:51:53.171842 zmc_dvideo1[13803].DB3-zm_local_camera.cpp/349 [Opening video device /dev/video1]
11/09/10 15:51:53.172220 zmc_dvideo1[13803].DB2-zm_local_camera.cpp/355 [V4L2 support enabled, using V4L1 api]
11/09/10 15:51:53.172282 zmc_dvideo1[13803].DB3-zm_local_camera.cpp/502 [Configuring picture attributes]
11/09/10 15:51:53.172357 zmc_dvideo1[13803].DB4-zm_local_camera.cpp/509 [Old P:0]
11/09/10 15:51:53.172410 zmc_dvideo1[13803].DB4-zm_local_camera.cpp/510 [Old D:8]
11/09/10 15:51:53.172468 zmc_dvideo1[13803].DB4-zm_local_camera.cpp/511 [Old B:0]
11/09/10 15:51:53.172517 zmc_dvideo1[13803].DB4-zm_local_camera.cpp/512 [Old h:0]
11/09/10 15:51:53.172563 zmc_dvideo1[13803].DB4-zm_local_camera.cpp/513 [Old Cl:0]
11/09/10 15:51:53.172609 zmc_dvideo1[13803].DB4-zm_local_camera.cpp/514 [Old Cn:32896]
11/09/10 15:51:53.172667 zmc_dvideo1[13803].DB3-zm_local_camera.cpp/551 [Configuring window attributes]
11/09/10 15:51:53.172723 zmc_dvideo1[13803].DB4-zm_local_camera.cpp/560 [Old X:0]
11/09/10 15:51:53.172770 zmc_dvideo1[13803].DB4-zm_local_camera.cpp/561 [Old Y:0]
11/09/10 15:51:53.172816 zmc_dvideo1[13803].DB4-zm_local_camera.cpp/562 [Old W:640]
11/09/10 15:51:53.172862 zmc_dvideo1[13803].DB4-zm_local_camera.cpp/563 [Old H:480]
11/09/10 15:51:53.172915 zmc_dvideo1[13803].DB3-zm_local_camera.cpp/578 [Setting up request buffers]
11/09/10 15:51:53.173125 zmc_dvideo1[13803].DB4-zm_local_camera.cpp/584 [vmb.frames = 4]
11/09/10 15:51:53.173177 zmc_dvideo1[13803].DB4-zm_local_camera.cpp/585 [vmb.size = 475136]
11/09/10 15:51:53.173224 zmc_dvideo1[13803].DB3-zm_local_camera.cpp/587 [Setting up 4 frame buffers]
11/09/10 15:51:53.173456 zmc_dvideo1[13803].DB3-zm_local_camera.cpp/612 [Configuring video source]
11/09/10 15:51:53.173590 zmc_dvideo1[13803].DB4-zm_local_camera.cpp/620 [Old C:0]
11/09/10 15:51:53.173634 zmc_dvideo1[13803].DB4-zm_local_camera.cpp/621 [Old F:0]
11/09/10 15:51:53.173672 zmc_dvideo1[13803].DB4-zm_local_camera.cpp/622 [Old Fl:0]
11/09/10 15:51:53.173711 zmc_dvideo1[13803].DB4-zm_local_camera.cpp/623 [Old T:2]
11/09/10 15:51:53.173788 zmc_dvideo1[13803].ERR-zm_local_camera.cpp/630 [Failed to set camera source 0: Invalid argument]
Any ideas?
Any ideas?
Switched the monitor Source settings to Video for Linux 2 (previously 1) and got a nice segfault trace:
11/09/10 16:19:16.176978 zmc_dvideo1[14057].DB3-zm_local_camera.cpp/349 [Opening video device /dev/video1]
11/09/10 16:19:16.177073 zmc_dvideo1[14057].DB2-zm_local_camera.cpp/355 [V4L2 support enabled, using V4L2 api]
11/09/10 16:19:16.177126 zmc_dvideo1[14057].DB3-zm_local_camera.cpp/360 [Checking video device capabilities]
11/09/10 16:19:16.177207 zmc_dvideo1[14057].DB3-zm_local_camera.cpp/370 [Setting up video format]
11/09/10 16:19:16.177280 zmc_dvideo1[14057].DB3-zm_local_camera.cpp/399 [Setting up request buffers]
11/09/10 16:19:16.177505 zmc_dvideo1[14057].DB3-zm_local_camera.cpp/427 [Setting up 8 data buffers]
11/09/10 16:19:16.177678 zmc_dvideo1[14057].DB3-zm_local_camera.cpp/465 [Configuring video source]
11/09/10 16:19:16.177747 zmc_dvideo1[14057].WAR-zm_local_camera.cpp/1219 [Brightness control is not supported]
11/09/10 16:19:16.177831 zmc_dvideo1[14057].INF-zm_local_camera.cpp/1220 [Brightness 1 0]
11/09/10 16:19:16.177912 zmc_dvideo1[14057].WAR-zm_local_camera.cpp/1279 [Hue control is not supported]
11/09/10 16:19:16.178066 zmc_dvideo1[14057].WAR-zm_local_camera.cpp/1336 [Saturation control is not supported]
11/09/10 16:19:16.178232 zmc_dvideo1[14057].DB3-zm_local_camera.cpp/654 [Setting up static colour tables]
11/09/10 16:19:16.178338 zmc_dvideo1[14057].DB2-zm_local_camera.cpp/1439 [Priming capture]
11/09/10 16:19:16.178395 zmc_dvideo1[14057].DB3-zm_local_camera.cpp/1443 [Queueing buffers]
11/09/10 16:19:16.178478 zmc_dvideo1[14057].DB3-zm_local_camera.cpp/1459 [Starting video stream]
11/09/10 16:19:18.089299 zmc_dvideo1[14057].DB2-zm_local_camera.cpp/1485 [Pre-capturing]
11/09/10 16:19:18.089515 zmc_dvideo1[14057].DB3-zm_local_camera.cpp/1491 [Capturing]
11/09/10 16:19:18.089608 zmc_dvideo1[14057].DB3-zm_local_camera.cpp/1514 [Capturing 1 frames]
11/09/10 16:19:18.163293 zmc_dvideo1[14057].DB3-zm_local_camera.cpp/1538 [Captured frame 0/1 from channel 0]
11/09/10 16:19:18.163418 zmc_dvideo1[14057].DB3-zm_local_camera.cpp/1572 [Doing format conversion]
11/09/10 16:19:18.163500 zmc_dvideo1[14057].DB3-zm_local_camera.cpp/1878 [Assigning image]
11/09/10 16:19:18.163748 zmc_dvideo1[14057].INF-zm_signal.cpp/72 [Got signal 11 (Segmentation fault), crashing]
Any workarounds or should I check out the source?
i have tried getting 1 to work and no luck. I tried the 320x240 in black and white. Its funny i can do this though. The cards are working just fine. Just not working in zoneminder.kingofkya wrote:First thing you should try to get working is one camera at the lowest resolution 320x240 and also b/w once you get that working you can move up to the higher resolution.
This way you can determine if it the capture card, shared mem, or other errors.
Here is my zoneminder with only 1 monitor configured. It shows the video is done loading but doesnt play nothing.
Also enabled debugging and ran this command.
root@ubuntu-test:~# tail -f /var/log/syslog
Nov 12 04:22:50 ubuntu-test zmdc[21427]: ERR ['zmc -d /dev/video' exited abnormally, exit status 6]
Nov 12 04:25:30 ubuntu-test zmdc[21427]: INF [Starting pending process, zmc -d /dev/video]
Nov 12 04:25:30 ubuntu-test zmdc[21427]: INF ['zmc -d /dev/video' starting at 10/11/12 04:25:30, pid = 21483]
Nov 12 04:25:30 ubuntu-test zmdc[21483]: INF ['zmc -d /dev/video' started at 10/11/12 04:25:30]
Nov 12 04:25:30 ubuntu-test zmc_dvideo[21483]: INF [Debug Level = 0, Debug Log = <none>]
Nov 12 04:25:30 ubuntu-test zmc_dvideo[21483]: INF [New Debug Level = 9, New Debug Log = /tmp/zm_debug .log.21483]
Nov 12 04:25:30 ubuntu-test zmc_dvideo[21483]: INF [Starting Capture]
Nov 12 04:25:30 ubuntu-test zmc_dvideo[21483]: FAT [Failed to stat video device /dev/video: No such fi le or directory]
Nov 12 04:25:30 ubuntu-test zmc_dvideo[21483]: INF [Got signal 6 (Aborted), exiting and forcing backtr ace]
Nov 12 04:25:30 ubuntu-test zmdc[21427]: ERR ['zmc -d /dev/video' exited abnormally, exit status 6]
root@ubuntu-test:/tmp# ls
zmaudit.log zm_debug.log.21417 zm_debug.log.21451 zm_debug.log.21471 zm_debug.log.21483 zmswap-m1 zmswap-m4
zmdc.log zm_debug.log.21425 zm_debug.log.21458 zm_debug.log.21474 zmfilter.log zmswap-m2 zmwatch.log
zmdc.sock zm_debug.log.21449 zm_debug.log.21459 zm_debug.log.21476 zmpkg.log zmswap-m3
root@ubuntu-test:/tmp# tail /tmp/zm_debug.log.21476
11/12/10 04:22:50.271736 zmc_dvideo[21476].DB9-zm_image.cpp/1316 [x:6, y:239.00]
11/12/10 04:22:50.271777 zmc_dvideo[21476].DB9-zm_image.cpp/1316 [x:5, y:239.00]
11/12/10 04:22:50.271817 zmc_dvideo[21476].DB9-zm_image.cpp/1316 [x:4, y:239.00]
11/12/10 04:22:50.271856 zmc_dvideo[21476].DB9-zm_image.cpp/1316 [x:3, y:239.00]
11/12/10 04:22:50.271896 zmc_dvideo[21476].DB9-zm_image.cpp/1316 [x:2, y:239.00]
11/12/10 04:22:50.271936 zmc_dvideo[21476].DB9-zm_image.cpp/1316 [x:1, y:239.00]
11/12/10 04:22:50.276565 zmc_dvideo[21476].DB1-zm_monitor.cpp/1814 [Loaded monitor 4(ServerRoom), 1 zones]
11/12/10 04:22:50.276624 zmc_dvideo[21476].INF-zmc.cpp/188 [Starting Capture]
11/12/10 04:22:50.277329 zmc_dvideo[21476].FAT-zm_local_camera.cpp/344 [Failed to stat video device /dev/video: No such file or directory]
11/12/10 04:22:50.277840 zmc_dvideo[21476].INF-zm_signal.cpp/64 [Got signal 6 (Aborted), exiting and forcing backtrace]
root@ubuntu-test:/tmp# ls -l /dev/video0
crw-rw-rw- 1 root video 81, 0 2010-11-04 06:43 /dev/video0
root@ubuntu-test:/tmp# ls -l /dev/video1
crw-rw-rw- 1 root video 81, 4 2010-11-04 06:43 /dev/video1
PLEASE HELP!
Users browsing this forum: No registered users and 12 guests
