Page 1 of 2
Zoneminder whit Ubuntu 10.04 desktop problem.
Posted: Tue Jul 06, 2010 4:00 pm
by leonel
Hello everyone I have a problem here which I hope can help me with, I have Ubunutu 10.04 desktop, I Installed ZoneMinder following instructions given in this guide
http://www.zoneminder.com/wiki/index.ph ... 10_Desktop was fine without any errors I did everything to the point 3.5 (Install Cambozola) included, I have the ip8330 and ip8332 Vivotek cameras I can run either, I show them images of how this set ZoneMinder.
what I'm doing wrong?
Posted: Tue Jul 06, 2010 5:26 pm
by bb99
Probably nothing. Did you reboot after setting shared memory? Continue with the installation instructions the next sections check your installation and will give you clues as to why no video.
Posted: Tue Jul 06, 2010 5:54 pm
by leonel
bb99 wrote:Probably nothing. Did you reboot after setting shared memory? Continue with the installation instructions the next sections check your installation and will give you clues as to why no video.
hi, thanks for answering, the following installation has to do with graphics cards, I have no card and mysql changes, my connection is by ip, it's really needed the rest of the installation of graphics cards, sorry for the noob question
pd: i modify the Shared Memory Limits and still equal
Posted: Wed Jul 07, 2010 6:30 am
by novazion
Did you try to install cambozola, and switched to mpeg in streaming method and asf for format (images settings)?
You should also switch debug on with a least 5 in debug level, to see excatly what happens.
Posted: Wed Jul 07, 2010 2:10 pm
by leonel
novazion wrote:Did you try to install cambozola, and switched to mpeg in streaming method and asf for format (images settings)?
thanks for the reply!
configurations as they are regarded as
look at this, any ideas?
I change the format of video at the camera before it was H.264 and put it as jpeg now and if I put in my firefox this address http: \ \ 192.168.1.10 \ video.mjpg you can see the video image. =(
Posted: Thu Jul 08, 2010 5:57 pm
by DREMA
Ok, so how do you view your cam wihtout zm? Whats the direct url to the video feed?
Bueno, como vez tu camara sin zm? Cual es la direccion que usas para ver la imagen?
Posted: Thu Jul 08, 2010 6:02 pm
by leonel
DREMA wrote:Ok, so how do you view your cam wihtout zm? Whats the direct url to the video feed?
thanks drema!
i can see the video image from firefox and vlc in this url
http://192.168.1.10/video.mjpg
Posted: Thu Jul 08, 2010 8:04 pm
by DREMA
Necesitas poner alguna contraseña o algo antes de ver la imagen? Podrias poner una captura de pantalla cuando entras en esa direccion? Trata de usar este sitio para guardar tu imagen y ponla escalada para q no ocupe toda la pagina.
http://imgur.com/
Posted: Thu Jul 08, 2010 11:30 pm
by leonel
DREMA wrote:Necesitas poner alguna contraseña o algo antes de ver la imagen? Podrias poner una captura de pantalla cuando entras en esa direccion? Trata de usar este sitio para guardar tu imagen y ponla escalada para q no ocupe toda la pagina.
http://imgur.com/
grcias por el consejo, no no necesito poner ninguna contraseña para ver el video
aqui esta la imagen
link tamaño original:
http://imgur.com/YWXKZ.png
saludos!
Posted: Fri Jul 09, 2010 12:49 am
by DREMA
Mmm puede que tu problema sea las medidas que pones para la imagen, en tus capturas se ve que pusiste 350x240, cuando la imagen que te da la camara es de 320x200, podrias tratar poniendo esas medidas y dejando todo lo demas como esta.
Posted: Fri Jul 09, 2010 3:32 pm
by bridgebr
I also have Ubuntu 10.04 and the same problem, no video. Tha same blank page.
Posted: Fri Jul 09, 2010 4:36 pm
by leonel
DREMA wrote:Mmm puede que tu problema sea las medidas que pones para la imagen, en tus capturas se ve que pusiste 350x240, cuando la imagen que te da la camara es de 320x200, podrias tratar poniendo esas medidas y dejando todo lo demas como esta.
lo habÃa intentado con muchas resoluciones ya que la cámara tiene desde 1280 para abajo y nada sucedió..
I had tried many resolutions as the camera is from 1280 down and nothing happened ..
I can not think what else to do...
Posted: Fri Jul 09, 2010 6:57 pm
by bridgebr
I can see my camera with cheese, xawtv or any other video app except for this. Leonel, did upgrade from a previous Ubuntu system, and if so did your camera work back then?
Puedo ver mi cámara con queso, xawtv o cualquier aplicación de vÃdeo, excepto para ello. Leonel, se actualiza de un anterior sistema, Ubuntu, y si es asà ¿su trabajo de cámara en aquel entonces?
Posted: Fri Jul 09, 2010 8:12 pm
by DREMA
@bridgebr What are your source settings?
Posted: Fri Jul 09, 2010 8:36 pm
by PacoLM
Hola,
Has probado con 320 x 240??
Saludos,
PacoLM
