Authentication question
Sergio
Post by Sergio »
I've been using Zoneminder for about 6 months now and it is stable, easy to use & reliable! Yippee! Thanks guys. Is it possible to make it so that all external connections to ZM must be authenticated, but internal connections do not? IE
Http://192.168.20.100 would not require a login to see the cameras.
Http://www.MyURL.com would require a login to see the cameras.
kingofkya
Post by kingofkya »
you might be able to achieve this with a htacces that auto logins for local connections.
