Sources keep going red, zma/zmc restart, ubuntu 9.10 x64
Posted: Wed Dec 30, 2009 12:13 pm
I'm hoping someone can help with this - I've recently upgraded my capture card to a generic 4 port saa7134, and at the same time, upgraded my ubuntu install.
I've also installed the latest v1.24.2 ZM ubuntu x64 release from ftp.northern-ridge.com.au/ I've also done the shared memory tweak.
The system mostly works, however, every so often, one or more of the source will go red for a while - at this point there is no video available and I assume that events will not be captured. The source will eventually come back on its own.
I first assumed that it might be a heat problem, since the saa7134 chips get quite warm, but I've added heat sinks to each chip, and a fan to keep them nice and cool.
I've played with all the settings I can think of - increasing the frame rate does seem to make it fail more often.
Any ideas?? Please!!
Here's some screen shots and system data:
rich@badboy:~$ cat /etc/issue
Ubuntu 9.10 \n \l
rich@badboy:~$ uname -r
2.6.31-16-generic
rich@badboy:~$ ps -e | grep 'zm'
6663 ? 00:00:52 zmdc.pl
6687 ? 00:58:18 zma
6691 ? 01:04:08 zma
6703 ? 00:00:00 zmfilter.pl
6705 ? 00:00:04 zmaudit.pl
6708 ? 00:00:24 zmwatch.pl
6711 ? 00:00:00 zmupdate.pl
14190 ? 00:13:34 zma
15111 ? 00:04:56 zma
16190 ? 00:00:09 zmc
16207 ? 00:00:06 zmc
16273 ? 00:00:02 zmc
top - 11:53:43 up 18:51, 1 user, load average: 0.10, 0.08, 0.08
Tasks: 246 total, 2 running, 244 sleeping, 0 stopped, 0 zombie
Cpu(s): 6.4%us, 0.2%sy, 0.0%ni, 69.0%id, 24.5%wa, 0.0%hi, 0.0%si, 0.0%st
Mem: 3992812k total, 2694396k used, 1298416k free, 399448k buffers
Swap: 5269280k total, 0k used, 5269280k free, 1604412k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
15111 www-data 20 0 212m 17m 14m S 8 0.4 5:01.82 zma
6687 www-data 20 0 212m 17m 14m S 8 0.4 58:24.64 zma
16410 www-data 20 0 214m 18m 16m S 3 0.5 0:00.10 zmc
6691 www-data 20 0 212m 16m 14m R 3 0.4 64:12.33 zma
16273 www-data 20 0 214m 18m 16m S 2 0.5 0:03.47 zmc
16207 www-data 20 0 214m 18m 16m S 2 0.5 0:07.79 zmc
16397 rich 20 0 19264 1436 980 R 1 0.0 0:00.25 top
6663 www-data 20 0 67356 9588 1600 S 0 0.2 0:52.70 zmdc.pl
1 root 20 0 19536 1872 1188 S 0 0.0 0:01.20 init
2 root 15 -5 0 0 0 S 0 0.0 0:00.00 kthreadd
3 root RT -5 0 0 0 S 0 0.0 0:00.01 migration/0
4 root 15 -5 0 0 0 S 0 0.0 0:00.05 ksoftirqd/0
5 root RT -5 0 0 0 S 0 0.0 0:00.00 watchdog/0
6 root RT -5 0 0 0 S 0 0.0 0:00.02 migration/1
7 root 15 -5 0 0 0 S 0 0.0 0:00.05 ksoftirqd/1
8 root RT -5 0 0 0 S 0 0.0 0:00.00 watchdog/1
9 root RT -5 0 0 0 S 0 0.0 0:00.00 migration/2
From modprobe settings:
roma_agc=1 combfilter=1 autoload=0 triton1=0 vsfx=0
alias char-major-81 videodev
alias char-major-81-0 saa7134
options saa7134 card=97,97,97,97
