Starting Script is Not Working [SOLVED]
Posted: Mon Dec 21, 2009 11:13 am
Yes there is. But still, i have to start zm manually from web interface. What's wrong there? And i counld not understand, what does the $RETVAL do?I've wrote: locate zmpkg.pl
/usr/local/bin/zmpkg.pl
ls -l /etc/init.d/zm
-rwxr-xr-x 1 root root 826 2009-12-13 13:56 /etc/init.d/zm
cat /etc/init.d/zm
#!/bin/sh
# description: Control ZoneMinder as a Service
# chkconfig: 2345 99 99
# Source function library.
#. /etc/rc.d/init.d/functions
prog=ZoneMinder
ZM_PATH_BIN="/usr/local/bin"
command="$ZM_PATH_BIN/zmpkg.pl"
start() {
echo -n "Starting $prog: "
$command start
RETVAL=$?
[ $RETVAL = 0 ] && echo success
[ $RETVAL != 0 ] && echo failure
return $RETVAL
stop() {
echo -n "Stopping $prog: "
$command stop
RETVAL=$?
status() {
result=`$command status`
if [ "$result" = "running" ]; then
echo "ZoneMinder is running"
RETVAL=0
else
echo "ZoneMinder is stopped"
RETVAL=1
fi
case "$1" in
'start')
start
'stop')
stop
'restart')
stop
start
'status')
status
echo "Usage: $0 { start | stop | restart | status }"
RETVAL=1
esac
exit $RETVAL
Edit: The solution is there
