Axis M1031W & Axis 221 - How to configure in ZM?
craver84
Post by craver84 » Thu Dec 17, 2009 5:34 pm
Hi everyone, I have a problem with my M1031 and Axis221
Here are my tests with M1031
Still Pictures: /axis-cgi/jpg/image.cgi
PATH                                                             FPS       kb/s
/axis-cgi/jpg/image.cgi?resolution=640x480&compression=20 		4,9	    300-360
/axis-cgi/jpg/image.cgi?resolution=640x480&compression=80 		5,2       85-100
/axis-cgi/jpg/image.cgi?resolution=320x240&compression=20 		5,4       130-170
/axis-cgi/jpg/image.cgi?resolution=320x240&compression=80 		5,8        25-30
MJPEG Video Streaming: /axis-cgi/mjpg/video.cgi
PATH                                                             FPS       kb/s
/axis-cgi/mjpg/video.cgi?resolution=640x480&compression=20		15       650-1300
/axis-cgi/mjpg/video.cgi?resolution=640x480&compression=80		15       350-420
/axis-cgi/mjpg/video.cgi?resolution=320x240&compression=20		15,3    360-390
/axis-cgi/mjpg/video.cgi?resolution=320x240&compression=80		15,3    110-125
the problem is that with MJPEG Video Streaming the image is not in real time but there is a delay between 2 and 15 seconds, and sometimes the TX is not stable (it goes to zero)
can anyone help me?
craver84
Post by craver84 » Fri Dec 18, 2009 2:22 pm
I can't understand why my Axis207 works great...
with this Remote Host Path
I've 15fps and a real time video, but it does't work with Axis 221 and M1031
craver84
Post by craver84 » Sat Dec 26, 2009 1:40 pm
noone?
Arsenal2
M1011-W
Post by Arsenal2 » Tue Jan 05, 2010 6:49 pm
I just received two Axis M1011-W and I will set them up tonight. I will post my findings.
What would you recommend?
mjpeg or mpeg4?
craver84
Post by craver84 » Tue Jan 05, 2010 7:08 pm
I use mjpeg. Let me know!
Arsenal2
Framerate
Post by Arsenal2 » Tue Jan 05, 2010 7:13 pm
At what framerate and size?
Arsenal2
Post by Arsenal2 » Tue Jan 05, 2010 7:28 pm
Nevermind. I see the above link... :oops:
Arsenal2
Delay
Post by Arsenal2 » Wed Jan 06, 2010 3:55 am
Ok.. Here is what I found. Using either MJPEG or MPEG4 streams there is a huge delay (5-15 seconds) at 640x480 or 320x240. I tried different compression levels from 10-90.... Same thing. I finally got it working but I am baffled why it only works at 5 fps.
Settings in zoneminder.
Max FPS 5
Max Alarm FPS 5
Remote protocol HTTP
Remote method Simple
Remote Host Path /axis-cgi/mjpg/video.cgi?resolution=320x240&compression=20
Capture Width 320
Capture Height 240
Settings on the M1011W
Resolution 320x240
Compression 20
Video Stream - Max Frame Rate - Limited to - 5 fps
The delay is barely noticeable and motion capture works great. The question I have is why can my browser view at 30fps but zoneminder will only work at 5 fps? The network has nothing else on it and both wired and wireless act the same. This is my first try with an IP camera and zoneminder so is this normal? My setup is a PV-149 capture card with two analog cameras, two usb cameras, and now two Axis M1011-W cameras. Load is 0.38 and all cameras are running at 320x240.
codabiz
Post by codabiz » Wed Jan 06, 2010 8:11 am
Have you tried setting the Max FPS to zero, and setting the framerate on the Axis cameras?
This has reduced the time delay for other Axis users.
craver84
Post by craver84 » Wed Jan 06, 2010 9:39 am
The same thing that appened to me.
with this setting
Axis 2100, Axis 205 & Axis 207 ->> work fantastic, about 10-12 fps
Axis M1031 & Axis 221 ->> working badly, delay. max 5fps
I'm glad (sorry Arsenal2 :oops: ) that someone else has my same problem...
Maybe it is due to the cams, but one thing let me dubious:
why the live view of the cam (http://your-cam-ip) is perfect?
Arsenal2
Post by Arsenal2 » Wed Jan 06, 2010 11:42 am
codabiz wrote:Have you tried setting the Max FPS to zero, and setting the framerate on the Axis cameras?
WOW!!! That worked! I removed the fps value in Zoneminder and bumped the cameras up to 15fps and everything works great. No delay. Awesome.
Thanks codabiz!
craver84
Post by craver84 » Wed Jan 06, 2010 4:46 pm
Really?that's great!!!!!
I will try it tomorrow! thank you all!
c0mputerking
Post by c0mputerking » Sat Feb 13, 2010 10:32 pm
Hello all i am having issues with the 1031-W I finally got something to see other than a black screen when using the /mpeg4/media.amp directory and setting the max frame rate of the camera to 15fps. I get an image only one when i click on the monitor it rarely seems to update states i am getting 4fps but image does not change more than once every 30s.
I have started a new post about it here please read it to see the error messages i continue to get
http://www.zoneminder.com/forums/viewtopic.php?t=15346
thanks in advance
Update once i closed the axis camera preview things began to work much better in Zoneminder however the image is still choppy and i still get these errors
Feb 13 15:47:25 ns1 zmc_m2[4584]: WAR [Packet in sequence, gap 3]
Feb 13 15:47:25 ns1 zmc_m2[4584]: WAR [Discarding frame 6875]
Feb 13 15:47:25 ns1 zmc_m2[4584]: WAR [Packet in sequence, gap 2]
Feb 13 15:47:28 ns1 zmc_m2[4584]: WAR [Packet in sequence, gap 28]
Feb 13 15:47:28 ns1 zmc_m2[4584]: WAR [Discarding frame 6928]
Feb 13 15:47:28 ns1 zmc_m2[4584]: WAR [Packet in sequence, gap 2]
