Problem is unexplained system crash with ZM running nothing really in the system logs to suggest why. no problems when ZM is stopped
System ubuntu 8.04 server 64bit running ZM v1.22.3. 8 channel phillips saa7130 based card currently using LifeView FlyVIDEO30 driver
Syslog is show lots for the following errors immediately prior to the crash:
Nov 1 12:29:59 fileserver zmc_dvideo1[12095]: ERR [Sync failure for frame 2 buffer 3(1): Input/output error]
Nov 1 12:29:59 fileserver zmdc[6394]: ERR ['zmc -d /dev/video1' exited abnormally, exit status 255]
Nov 1 12:30:06 fileserver zmwatch[6433]: INF [Restarting capture daemon for ShopBack, time since last capture 7 seconds (1257078606-1257078599)]
Nov 1 12:30:06 fileserver zmdc[12099]: INF ['zmc -d /dev/video1' started at 09/11/01 12:30:06]
Nov 1 12:30:06 fileserver zmdc[6394]: INF ['zmc -d /dev/video1' starting at 09/11/01 12:30:06, pid = 12099]
Nov 1 12:30:06 fileserver zmc_dvideo1[12099]: INF [Debug Level = 0, Debug Log = <none>]
Nov 1 12:30:06 fileserver zmwatch[6433]: INF ['zmc -d /dev/video1' starting at 09/11/01 12:30:06, pid = 12099]
Nov 1 12:30:06 fileserver zmc_dvideo1[12099]: INF [Starting Capture]
Nov 1 12:30:17 fileserver zma_m1[6733]: INF [ShopFront: 718000 - Processing at 9.90 fps]
