Techwell 6802 and 6805 cards
Moderator: zoneminder
BuffalM
Postby BuffalM » Mon Jul 20, 2009 12:36 am
Has anyone had any luck using the techwell tw680x cards with zoneminder?
I see there are fairly recent drivers being developed here: http://gitorious.org/tw68
Auctions for Chinese cards based on the techwell 6802/5 10-bit ADC chips are cheap compared to the CX2388x and BT8xx based cards. The 4 channel 120fps cards seem to come in two varieties 4 x TW6802B chips or 2 x TW6805 chips. There is also an 8 channel card with 4 x TW6805 chips for only a few bucks more.. Can anyone explain the difference between the 6802 and the 6805? If these cards now work with linux, I'd be interested to know if the TW6805 can run two channels well from the same chip because its a bit cheaper.
BuffalM
Postby BuffalM » Mon Jul 20, 2009 11:17 pm
From the differences between the two I can spot at the techwell website: the 6805 can operate on a 66mhz clock and has lower power consumption. It also looks like the 6805 can only do one channel real time per chip. That makes me assume that the two chip cards will not do 120fps, can someone confirm or correct?
djr
Postby djr » Sun Aug 30, 2009 12:08 pm
hi there,
did you ever have any luck getting these cards working under linux?
looking at them on ebay at the moment.
cheers,
dave
DREMA
Postby DREMA » Thu Sep 03, 2009 9:31 pm
I also have one of this cards working with windows until someone develop a driver and I can use it with zoneminder.
Any news are welcome.
BuffalM
Postby BuffalM » Fri Sep 04, 2009 1:58 am
I couldn't justify the cost if it wasn't going to work so I shelled out a little more for a bt878 based card. It looks like the link in the first post hasn't had any new code changes in a while. At the time it looked like it was still going and might be viable.
wbrack
Postby wbrack » Mon Feb 15, 2010 7:05 pm
TW68xx Driver Developer
Return to “Hardware Queries”
