Page 1 of 1
ACTi Preset missing Remote Sub Path
Posted: Thu Jul 02, 2009 7:38 pm
by caprio
I just did a fresh install of 1.24.2 on Ubuntu Hardy 64bit
After adding a new zone my ACTi IP camera's are not working.
I noticed that there is no longer a 'Remote Host SubPath' on the Source tab.
Was this by design or did it slip through the cracks?
My 1.24.1 install filled in the value '/track' when selecting the preset for ACTi unicast.
/var/log/messages:
Jul 2 12:37:45 zm1 zmc_m1[7283]: WAR [Discarding packet for unrecognised ssrc 25e12ce9]
Jul 2 12:37:45 zm1 zmc_m1[7283]: WAR [Discarding packet for unrecognised ssrc 5c305b5a]
Jul 2 12:37:45 zm1 zmc_m1[7283]: WAR [Discarding packet for unrecognised ssrc a0ab6c19]
Jul 2 12:37:45 zm1 zmc_m1[7283]: WAR [Discarding packet for unrecognised ssrc 45d39c8d]
Jul 2 12:37:45 zm1 zmc_m1[7283]: WAR [Discarding packet for unrecognised ssrc 5223653f]
Jul 2 12:37:45 zm1 zmc_m1[7283]: WAR [Discarding packet for unrecognised ssrc 31902f0b]
Jul 2 12:37:45 zm1 zmc_m1[7283]: WAR [Discarding packet for unrecognised ssrc 2c4d8d94]
Jul 2 12:37:45 zm1 zmc_m1[7283]: WAR [Discarding packet for unrecognised ssrc 1b1508f1]
Jul 2 12:37:45 zm1 zmdc[6928]: INF ['zmc -m 1' crashed, signal 8]
Jul 2 12:37:45 zm1 zmwatch[6959]: INF ['zmc -m 1' stopping at 09/07/02 12:37:39]
Jul 2 12:37:55 zm1 zmwatch[6959]: INF [Restarting capture daemon for CompRmWest, time since last capture 30 seconds (1246563475-1246563445)]
Jul 2 12:37:55 zm1 zmdc[7292]: INF ['zmc -m 1' started at 09/07/02 12:37:55]
Jul 2 12:37:55 zm1 zmdc[6928]: INF ['zmc -m 1' starting at 09/07/02 12:37:55, pid = 7292]
Jul 2 12:37:55 zm1 zmwatch[6959]: INF ['zmc -m 1' starting at 09/07/02 12:37:55, pid = 7292]
Jul 2 12:37:55 zm1 zmc_m1[7292]: INF [Debug Level = 0, Debug Log = <none>]
Jul 2 12:37:55 zm1 zmc_m1[7292]: INF [Starting Capture]
Jul 2 12:38:02 zm1 zmc_m1[7292]: WAR [Discarding packet for unrecognised ssrc 58e0a53c]
Posted: Tue Jul 07, 2009 12:54 am
by cordel
See here> http://www.zoneminder.com/forums/viewto ... 4021#54021
Yes it's intentional, You can use the preset to reset it.
Remote host sub-path
Posted: Tue Jul 07, 2009 5:54 pm
by caprio
I looked over the forum post you suggested however it didn't yield any clues.
Not having access to the ACTi API make it difficult to figure out whats needed
for the remote RTSP settings. I used the one and only ACTi preset in 1.24.1 which
worked without a hitch. cordel suggested that I use the preset to 'reset it' but I'm not
sure what he means.
Can someone tell me why the 'Remote Host SubPath' is no longer needed in the
1.24.2 ACTi preset? Why was it set to '/track' in 1.24.1 which did work?
I can capture and play back streams using ffmpeg and mplayer.
# ffmpeg -i rtsp://10.16.100.104:7070 /tmp/cam.avi
# mplayer -vo x11 /tmp/cam.avi
I'm using the ffmpeg 0.5 code base. Should I be using a more recent code base for
zm 1.24.2?
My symptoms are the monitor shows a solid gray box with the date and time in the
top left corner. zmdc.log reports:
07/07/09 05:51:16.373699 zmdc[7435].INF ['zmc -m 2' crashed, signal 8]
07/07/09 05:51:26.457902 zmdc[7435].INF ['zmc -m 2' starting at 09/07/07 05:51:26, pid = 19139]
07/07/09 05:51:46.540527 zmdc[7435].INF ['zmc -m 2' stopping at 09/07/07 05:51:46]
07/07/09 05:51:52.542839 zmdc[7435].INF ['zmc -m 2' crashed, signal 8]
07/07/09 05:52:02.625981 zmdc[7435].INF ['zmc -m 2' starting at 09/07/07 05:52:02, pid = 19145]
07/07/09 05:52:22.707100 zmdc[7435].INF ['zmc -m 2' stopping at 09/07/07 05:52:22]
07/07/09 05:52:28.709381 zmdc[7435].INF ['zmc -m 2' crashed, signal 8]
ZM debug shows errors decoding frames:
07/07/09 10:28:25.108353 zmc_m2[-1].DB5-zm_rtp_source.cpp/87 [Seq: 22947]
07/07/09 10:28:25.108362 zmc_m2[-1].DB3-zm_rtp_source.cpp/117 [Packet in sequence, gap 1]
07/07/09 10:28:25.108372 zmc_m2[-1].DB4-zm_rtp_source.cpp/259 [16: 5b 09 8a 0b 58 1b 0d 03 a6 58 44 c8 32 33 f5 78]
07/07/09 10:28:25.108384 zmc_m2[-1].DB4-zm_rtp_source.cpp/262 [16: 0e 3c 3d 0e 74 e9 50 74 38 21 05 76 96 30 44 23]
07/07/09 10:28:25.108395 zmc_m2[-1].DB2-zm_rtp_source.cpp/268 [Got new frame 1, 36480 bytes]
07/07/09 10:28:25.108405 zmc_m2[-1].DB8-zm_thread.cpp/215 [Updating value with signal, 0x7fee3c00a0d8]
07/07/09 10:28:25.108419 zmc_m2[-1].DB9-zm_thread.cpp/221 [Updated value, 0x7fee3c00a0d8]
07/07/09 10:28:25.108426 zmc_m2[-1].DB9-zm_thread.cpp/209 [Got value update, 0x7fee3c00a0d8]
07/07/09 10:28:25.108430 zmc_m2[-1].DB8-zm_thread.cpp/201 [Waiting for value update, 1 secs, 0x7fee3c00a140]
07/07/09 10:28:25.108456 zmc_m2[-1].DB8-zm_thread.cpp/127 [Waiting for 1 seconds]
07/07/09 10:28:25.108461 zmc_m2[-1].DB8-zm_thread.cpp/215 [Updating value with signal, 0x7fee3c00a140]
07/07/09 10:28:25.108489 zmc_m2[-1].DB9-zm_thread.cpp/221 [Updated value, 0x7fee3c00a140]
07/07/09 10:28:25.108493 zmc_m2[-1].DB9-zm_thread.cpp/209 [Got value update, 0x7fee3c00a140]
07/07/09 10:28:25.108499 zmc_m2[-1].DB3-zm_rtp_source.cpp/323 [Copied 36480 bytes]
07/07/09 10:28:25.108516 zmc_m2[-1].DB5-zm_rtp_source.cpp/164 [Delta rtp = 0.646869]
07/07/09 10:28:25.108523 zmc_m2[-1].DB3-zm_remote_camera_rtsp.cpp/175 [Read frame 36480 bytes]
07/07/09 10:28:25.108543 zmc_m2[-1].DB5-zm_rtp_source.cpp/166 [Local RTP time = e36c]
07/07/09 10:28:25.108560 zmc_m2[-1].DB4-zm_remote_camera_rtsp.cpp/176 [Address 0x7fee449cd010]
07/07/09 10:28:25.108573 zmc_m2[-1].DB5-zm_rtp_source.cpp/167 [Packet RTP time = 5484087c]
07/07/09 10:28:25.108590 zmc_m2[-1].DB4-zm_remote_camera_rtsp.cpp/177 [16: 0e 3c 3d 0e 74 e9 50 74 38 21 05 76 96 30 44 23]
07/07/09 10:28:25.108608 zmc_m2[-1].DB5-zm_rtp_source.cpp/169 [Packet transit RTP time = ffffffffab7cdaf0]
07/07/09 10:28:25.108640 zmc_m2[-1].DB5-zm_rtp_source.cpp/175 [Jitter D = 30]
07/07/09 10:28:25.108653 zmc_m2[-1].DB5-zm_rtp_source.cpp/187 [RTP Jitter: 3200]
07/07/09 10:28:25.108791 zmc_m2[-1].ERR-zm_remote_camera_rtsp.cpp/216 [Error while decoding frame 1]
07/07/09 10:28:25.108828 zmc_m2[-1].ERR-zm_remote_camera_rtsp.cpp/217 [256: 0e 3c 3d 0e 74 e9 50 74 38 21 05 76 96 30 44 23 3f 41 c5 9d 14 14 05 e3 98 0e cb 52 91 02 3a 40 dc 9d e8
b0 70 b0 6c 0b f4 48 b0 b0 a1 29 b1 19 4a c1 6a 0e e0 c5 38 68 37 18 88 7a ce 08 4c 27 06 23 a3 9c 19 88 ec 1c 20 26 1a 82 bc 50 9f 68 6d a1 89 48 da 88 29 dc f1 1d 87 e3 90 4d 0e
90 88 69 06 8d b0 58 c8 84 b2 23 0d 2e 53 59 c8 a0 0c f0 47 9b cf c8 d9 f4 96 88 47 04 6d 14 68 dc f7 04 24 36 e8 6d c0 09 69 32 46 7b ce a5 e6 24 bd 36 0e 66 a5 e5 4e db 27 83 92
80 a4 46 b7 83 80 60 dd 93 d5 8c 58 6e da 51 10 54 58 8f 8c 36 1c 12 02 7d c5 d9 59 10 75 a6 c4 7d 46 38 01 6b 96 22 1c 9d 68 35 9c 1b 10 03 c7 7f f6 d8 77 d2 c3 ff 2a b4 62 23 3f
16 32 0e 1b 0d 1b 6d 02 28 c2 39 e1 ad d5 98 8c d6 12 b5 cd 14 8e 34 23 11 aa 70 d6 a5 d9 91 65 0f 2b 62 af d5 b5 0c 2b 27]
07/07/09 10:28:25.108881 zmc_m2[-1].DB3-zm_rtp_source.cpp/312 [Getting frame]
07/07/09 10:28:25.108892 zmc_m2[-1].DB8-zm_thread.cpp/201 [Waiting for value update, 1 secs, 0x7fee3c00a0d8]
07/07/09 10:28:25.108903 zmc_m2[-1].DB8-zm_thread.cpp/127 [Waiting for 1 seconds]
Posted: Tue Jul 07, 2009 6:26 pm
by cordel
cordel wrote:See here> http://www.zoneminder.com/forums/viewto ... 4021#54021
Leads to:
zoneminder wrote:If you change to 1.24.2 then you no longer need (or can modify) the sub path so can throw that away. There are other changes also that may help. I have a Vivotek that works fine with port 554, RTP/Unicast and live.sdp as the host path.
Use the preset like you are setting the camera up for the first time to insure the values from the preset are in place. The field is gone, it is intentional and likely not coming back.
Posted: Tue Jul 07, 2009 7:53 pm
by caprio
OK. Great. Thank you for the clarification.
