Time Based Recording Functions?
quietas
Post by quietas » Tue Jun 23, 2009 9:52 pm
Is there any way to have a camera record during one set time and motion detect another?
My thoughts are during the daytime hours in which people are expected to be at work, motion detecting would be a waste of time as there would always be people in view. Then after hours change to modect since no one would be there normally.
kingofkya
Post by kingofkya » Sun Jun 28, 2009 5:03 am
How can I get ZM to do different things at different times of day or week?
Now you can switch between these two states by selecting them from the same dialog you saved them, or from the command line from issue the command zmpkg.pl <run state>, for example zmpkg.pl Daytime.
The final step you need to take, is scheduling the time the changes take effect. For this you can use cron. A simple entry to change to the Daylight state at at 8am and to the nighttime state at 8pm would be as follows,
0 8 * * * /usr/local/bin/zmpkg.pl Daytime
0 20 * * * /usr/local/bin/zmpkg.pl Nighttime
On Ubuntu 7.04 and possibly others, look in /usr/bin not just /usr/local/bin for the zmpkg.pl file.
For an alternative method of time controlling ZoneMinder, forum user 'voronwe' has created a more interactive calendar style integration. Details of this can be found in this forum thread. If you would like to find out more about this contribution please post on this thread.
from FAQ http://www.zoneminder.com/wiki/index.php/FAQ
quietas
Post by quietas » Mon Jun 29, 2009 6:33 pm
Thanks, I missed that one.
Users browsing this forum: No registered users and 15 guests
