No picture's on events or live.
Jeroenl
Post by Jeroenl »
After successfully having zm 1.23.3 running on ubuntu 7.10 I messed up my system. And i installed Ubuntu 8.10. Also installed zm 1.24 and compiled it. ( my first non .deb install!!!!! )
Beeing very proud and stuf i installed the first monitor. It turned green! yeah!
BUT
Its recording. i can see the jpeg file's on my harddrive
and i dont think there is a rights problem :
root@laptop:/home/jeroen# ls -l /var/www/html/events/
total 4
drwxr-xr-x 53 600 www-data 4096 2008-12-30 19:40 1
lrwxrwxrwx  1 600 www-data    1 2008-12-30 07:25 New -> 1
I am using Firefox 3 but when i connected from a windows machine using IE i also dont see any image's
timf
I had a similar problem.....
Post by timf »
check your apache log and see where it's looking for zms or nph-zms.
Also check your shared memory settings.
nuck
Re: No picture's on events or live.
Post by nuck »
Jeroenl wrote:I am using Firefox 3 but when i connected from a windows machine using IE i also dont see any image's
Are you set up for jpeg or mpeg streams? Do you have cambazola installed?
