Bt 878/Generic difficulties
Posted: Mon Dec 22, 2008 10:10 pm
Hi all,
ZoneMinder 1.23.3
First time trying to set up zoneminder and I'm having some difficulties with a bt878 card.
The actual card (I think) is an Adlink Angelo RTV-24 (identified by the picture on bttv gallery)
I have tried everything I can think of. The camera works (plugged it into a TV) the card driver SEEMS to load but all I ever get is a blue screen in xawtv.
I've played around with modprobe options and xawtv settings, etc. but am at my wits end.
the output from lspci -v looks like this:
02:00.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Subsystem: Unknown device 32da:c84e
Flags: bus master, medium devsel, latency 64, IRQ 11
Memory at f8007000 (32-bit, prefetchable)
Capabilities: [44] Vital Product Data
Capabilities: [4c] Power Management version 2
02:00.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Flags: medium devsel, IRQ 11
Memory at f8006000 (32-bit, prefetchable)
I'm a little worried about the Subsystem:Unknown.
dmesg looks like tthis:
device-mapper: 4.5.0-ioctl (2005-10-04) initialised: dm-devel@redhat.com
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
Capability LSM initialized
Linux agpgart interface v0.101 (c) Dave Jones
Linux video capture interface: v1.00
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
bttv0: Bt878 (rev 17) at 0000:02:00.0, irq: 11, latency: 64, mmio: 0xf8007000
bttv0: subsystem: 32da:c84e (UNKNOWN)
please mail id, board name and the correct card= insmod option to video4linux-list@redhat.com
bttv0: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv0: gpio: en=00000000, out=00000000 in=00ff0aff [init]
bttv0: using tuner=-1
bttv0: i2c: checking for MSP34xx @ 0x80... not found
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: i2c: checking for TDA9887 @ 0x86... not found
bttv0: registered device video0
bttv0: registered device vbi0
bttv: Bt8xx card found (1).
bttv1: Bt878 (rev 17) at 0000:02:04.0, irq: 11, latency: 64, mmio: 0xf8005000
bttv1: subsystem: 32db:c84e (UNKNOWN)
bttv1: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv1: gpio: en=00000000, out=00000000 in=00ff7eff [init]
bttv1: using tuner=-1
bttv1: i2c: checking for MSP34xx @ 0x80... not found
bttv1: i2c: checking for TDA9875 @ 0xb0... not found
bttv1: i2c: checking for TDA7432 @ 0x8a... not found
bttv1: i2c: checking for TDA9887 @ 0x86... not found
bttv1: registered device video1
bttv1: registered device vbi1
bttv: Bt8xx card found (2).
bttv2: Bt878 (rev 17) at 0000:02:08.0, irq: 11, latency: 64, mmio: 0xf8003000
bttv2: subsystem: 32dc:c84e (UNKNOWN)
bttv2: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv2: gpio: en=00000000, out=00000000 in=00ffbeff [init]
bttv2: using tuner=-1
bttv2: i2c: checking for MSP34xx @ 0x80... not found
bttv2: i2c: checking for TDA9875 @ 0xb0... not found
bttv2: i2c: checking for TDA7432 @ 0x8a... not found
bttv2: i2c: checking for TDA9887 @ 0x86... not found
bttv2: registered device video2
bttv2: registered device vbi2
bttv: Bt8xx card found (3).
bttv3: Bt878 (rev 17) at 0000:02:0c.0, irq: 11, latency: 64, mmio: 0xf8001000
bttv3: subsystem: 32dd:c84e (UNKNOWN)
bttv3: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv3: gpio: en=00000000, out=00000000 in=00fffcff [init]
bttv3: using tuner=-1
bttv3: i2c: checking for MSP34xx @ 0x80... not found
bttv3: i2c: checking for TDA9875 @ 0xb0... not found
bttv3: i2c: checking for TDA7432 @ 0x8a... not found
bttv3: i2c: checking for TDA9887 @ 0x86... not found
bttv3: registered device video3
bttv3: registered device vbi3
bt878: AUDIO driver version 0.0.0 loaded
bt878: Bt878 AUDIO function found (0).
bt878_probe: card id=[0xc84e32da], Unknown card.
Exiting..
bt878: probe of 0000:02:00.1 failed with error -22
bt878_probe: card id=[0xc84e32db], Unknown card.
Exiting..
bt878: probe of 0000:02:04.1 failed with error -22
bt878_probe: card id=[0xc84e32dc], Unknown card.
Exiting..
bt878: probe of 0000:02:08.1 failed with error -22
bt878_probe: card id=[0xc84e32dd], Unknown card.
Exiting..
I see the bt878 module trying to load and failing. I've tried removing the module from the kernel and am not really sure what the difference is between bt878 and bttv.
Anyways - I'm about to give up on this card but thought someone here might have some insight.
thanks for any help!!
ZoneMinder 1.23.3
Exiting..
Exiting..
Exiting..
Exiting..
