to unload a module you could use rmmod and then do
modprobe again
but nice thanks for the trick
i searched google and also found this:
# modinfo gspca | grep parm
parm: autoexpo:Enable/Disable auto exposure (default=1: enabled) (PC-CAM 600/Zc03xx/spca561a/Etoms Only !!!) (int)
parm: debugebug level: 0=none, 1=init/detection, 2=warning, 3=config/control, 4=function call, 5=max (int)
parm: force_rgb:Read RGB instead of BGR (int)
parm: gamma:gamma setting range 0 to 7 3-> gamma=1 (int)
parm: OffRed:OffRed setting range -128 to 128 (int)
parm: OffBlue:OffBlue setting range -128 to 128 (int)
parm: OffGreen:OffGreen setting range -128 to 128 (int)
parm: GRed:Gain Red setting range 0 to 512 /256 (int)
parm: GBlue:Gain Blue setting range 0 to 512 /256 (int)
parm: GGreen:Gain Green setting range 0 to 512 /256 (int)
parm: compress:Turn on/off compression (not functional yet) (int)
parm: usbgrabber:Is a usb grabber 0x0733:0x0430 ? (default 1) (int)
parm: lightfreq:Light frequency banding filter. Set to 50 or 60 Hz, or zero to NoFliker (default=50) (int)
you have lots of other options
and about changing the options i saw those examples:
#echo "4" > /sys/module/gspca/parameters/gamma
#echo "240" > /sys/module/gspca/parameters/GRed
