what is the best input stream format from IP-cams in terms of low CPU-load ?
Is it mjpeg ? Is there a difference if zoneminder grabs single .jpgs or a mjpeg stream from an IP-cam ?
Thanks !
What´s the best input stream format (IP-cams) for zm ?
no difference in load ut usually mjpeg is caperble of higher framerates
James Wilson
no, the load is dependant upon framreate, ie 5fps of mjpeg will have the same load as 5 fps of jpeg
James Wilson
