Page 1 of 1
Axis 215ptz problem: zmwatch.log:shared memory not valid
Posted: Wed Dec 12, 2007 9:05 am
by steasy
I have a problem with my Axis 215 ptz new cam.
the image does not appear and the system don't record anything.
the other axis (a 207w) work's well at 640*480.
I have already tried to increase memory to 428212224 Byte (as the faq says:
kernel.shmall = 428212224
kernel.shmmax = 428212224
the address in host i'have tried are :
/axis-cgi/mjpg/video.cgi?resolution=4CIF
/axis-cgi/mjpg/video.cgi?resolution=705x576
(is not an autentication problem because i use the same autentication parameters than the 207w)
Anyone can help me?
where i'm wrong?
thank you a lot.
i use 1.22.3 on ubuntu latest
*****update****
here the copy of /tmp/zmwatch.log
12/13/07 22:19:40.101882 zmwatch[6256].INF ['zmc -m 3' starting at07/12/13 22:19:40, pid = 6404]
12/13/07 22:19:50.119515 zmwatch[6256].ERR [Can't get shared memory id '7a6d2003', 3: No such file or directory]
12/13/07 22:19:50.119700 zmwatch[6256].INF [Restarting capture daemon for cam, shared memory not valid]
12/13/07 22:19:50.210708 zmwatch[6256].INF ['zmc -m 3' starting at 07/12/13 22:19:50, pid = 6413]
thanks
Stefano
Posted: Wed Dec 30, 2009 11:19 pm
by tahi
Hi
I know it's a very old post but have you find a solution?
I have same problem with my 215PTZ :(
Posted: Sat Jan 02, 2010 1:10 pm
by codabiz
Can you get a single JPEG images in a browser with the path, say:
<IP>/axis-cgi/jpg/image.cgi?resolution=CIF
Posted: Wed Mar 17, 2010 12:00 pm
by dougwright
Had the same problem. I used the following source settings to make it work:
Protocol: RTSP
Method: RTP/RTSP
Port: 554
Path: /mpeg4/media.amp
Colours: 24 bit
Width: 704
Height: 576
