Page 1 of 1
Regexp
Posted: Mon Oct 08, 2007 7:47 pm
by denis
is it possible to introduce in some way
the possibility to enable or disable regexp
for camera and not globally?
thank you!
is it still anywhere?
Posted: Wed Sep 23, 2009 6:56 pm
by preachermanx
I have the latest/greatest build [from source] and I don't seem to have the ability to select REGEXP as the method, and the reccomended fix for the "invalid JPEG file structure" problem I am having is to turn it on.
Did I miss a configure option or something that enables regular expressions?
Posted: Wed Sep 23, 2009 8:03 pm
by knight-of-ni
For Zoneminder 1.24.2, open a Monitor Config Window, select the Source Tab, and then change the Remote Method from "Simple" to "Regexp".
