tibetfreedom wrote:Oh I see what is wrong,
In the logs there it says
2011-11-12 19:07:14.308547 web_php 26614 ERR socket_sendto( /tmp/zm/zms-206990s.sock ) failed: No such file or directory zm/includes/functions.php 2322
2011-11-12 19:07:09.443100 web_js 26614 ERR TypeError: 'undefined' is not a function undefined
2011-11-12 19:07:09.325349 zms 27253 ERR Terminating, last frame sent time 1321124829.167867 secs more than maximum of 10.000000 zm_monitor.cpp 3683
2011-11-12 19:07:09.292417 zms 27253 ERR libjpeg-turbo is required for JPEG encoding directly from RGB32 source zm_image.cpp 810
so I guess it is not installed, it was before the upgrade…
What have I missed ?
also if I manually stop and start zm I see this…
root@CCTV:~# service zm stop
$Stopping ZoneMinder:
No option 'ZM_CPU_EXTENSIONS' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_LOG_LEVEL_SYSLOG' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_LOG_LEVEL_FILE' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_LOG_LEVEL_WEBLOG' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_LOG_LEVEL_DATABASE' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_LOG_DATABASE_LIMIT' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_LOG_DEBUG' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_LOG_DEBUG_TARGET' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_LOG_DEBUG_LEVEL' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_LOG_DEBUG_FILE' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_LOG_CHECK_PERIOD' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_LOG_ALERT_WAR_COUNT' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_LOG_ALERT_ERR_COUNT' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_LOG_ALERT_FAT_COUNT' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_LOG_ALARM_WAR_COUNT' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_LOG_ALARM_ERR_COUNT' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_LOG_ALARM_FAT_COUNT' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_UPLOAD_PROTOCOL' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_UPLOAD_HOST' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_UPLOAD_PORT' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_UPLOAD_USER' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_UPLOAD_PASS' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_UPLOAD_LOC_DIR' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_UPLOAD_REM_DIR' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_UPLOAD_TIMEOUT' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
No option 'ZM_UPLOAD_DEBUG' found, removing at /usr/local/share/perl/5.10.1/ZoneMinder/ConfigAdmin.pm line 89.
success
[: 61: 0 !=: unexpected operator
/etc/init.d/zm: 61: : not found
root@CCTV:~#
root@CCTV:~# service zm start
Starting ZoneMinder:
success
touch: cannot touch `/var/lock/subsys/zm': No such file or directory
root@CCTV:~#
root@CCTV:~#
