Windows Live Viewer..27-11-05 Now Complete Frontend for ZM!!
I will add it to the list. I am working on some additions and will see if i can add this.
btw i wasnt sure is full screen view was used much, how do you get on with it?
James Wilson
ZM4MS and HTTPS
Has any been able to get this to work?
I have my setup working over HTTP, but I would like to switch it over to HTTPS. From the ZM Server side I do not see any requests coming into apache over SSL. I do see the HTTP requests. The following URL works in a browser (after accepting the certificate).
https://my_host_name/cgi-bin/nph-zms?mode=single&monitor=3&scale=100&maxfps=15&auth=aeb3290a47038a9df6b29b756d317f41&rand=1228659780
What am I missing to make it work with ZM4MS.
BTW I think this is a great peace of software. Thank you James.
TIA,
Tim
TIA,
Tim
i think (never used https) you need to install the cert in ie.
Basically zm4ms uses proxy info etc and certs from ie.
It pulls the settings from ie as it uses built in http commands from ie. If you have a problem with ie you will have a problem with zm4ms.
If that dont work let me know and i will do some testing
James Wilson
have you entered your zm config and got any images before using dualhead mode? From your screen shots it appears you havnt set it up correctly
James Wilson
dear james!!
ZM config is okay - almost have images - in this case I turn off the camera,
![Image](http://www.congthanhgroup.com/demo/errorZM4MS-03.JPG)
![Image](http://www.congthanhgroup.com/demo/errorZM4MS-04.JPG)
I think maybe .Net framework proplems ...See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidCastException: Conversion from string "" to type 'Integer' is not valid. ---> System.FormatException: Input string was not in a correct format.
at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDouble(String Value, NumberFormatInfo NumberFormat)
at Microsoft.VisualBasic.CompilerServices.Conversions.ToInteger(String Value)
--- End of inner exception stack trace ---
at ViseonViewer2.dualHead.Timer2_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
ViseonViewer2
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Documents%20and%20Settings/CDBao/Local%20Settings/Apps/2.0/L85P3ML0.LD9/YVB7GADC.JLJ/vise..tion_0a282930b5e4c390_0001.0000_50a11aef0e65b37f/ViseonViewer2.exe
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
not sure but i doubt it.
have you only entered 1 monitor?
try duplicating that for all 4,
Also i have noticed issues when custom view 1 and 2 have no saved setup so just save 2 views in there.
Let me know how that goes
James Wilson
Thank you cdbao
Actually now might be a bit to small
But certainly makes the page load much faster
Might look for something in the middle or cropping just the important stuff.
For example the error window above is all that is useful all the pictures area is not as necessary. But it certainly still needs to be readable.
Just hate to see something get over looked because someone gets impatient waiting for the page. I know I do some times and I'm sure I'm not the only one.
![Very Happy :D](./images/smilies/icon_biggrin.gif)
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
![Cool 8)](./images/smilies/icon_cool.gif)
to start with id put the refresh rates up at say 10000
then try and save the custom views to anything.
I have had reports of this a couple of times but never been able to track it down
James Wilson
