YUM RPM Repo FC3 now available. UPDATED 2005-11-23
zoneminder
Site Admin
Post by zoneminder »
I have two boxes now so I can donate an account on one of them also. It's pretty solid and hasn't been down for months I think. Unlike this one :lol:
Phil
mfflynn
Post by mfflynn »
I am also getting the error:
# yum update
Setting up Update Process
Setting up Repos
Cannot find a valid baseurl for repo: ctu-updates-released
Is this server back up or is there another server I could point yum too?
jameswilson
Post by jameswilson »
i think corey is still down, and his is the only servers that run the autoupdate. He should be back up soon though
James Wilson
mfflynn
export and stream mpeg video?
Post by mfflynn »
I have installed the CD and setup a camera on zm with little to know problem, but when I try to switch the "video streaming method" or "export an event" to a video i get errors or no picture. Does the streaming / video export features not come pre-installed on the fedora 3 CD version? I found a binary on the server for ffmpeg, but I'm not sure if it was complied in.
If this is not a standard feature, what is the best way to install it?
Thanks.
jameswilson
I beleive the cd was built with a minor 'mistake' and the yum update will fix that when corey's servers are back. Unfortunatly i dont use the vid creation of zm so i personally cannot help here
James Wilson
cordel
Post by cordel »
The server is now somewhat online.
I'm looking into getting an account at godaddy to place everything. The only thing really left to figure out is how to limit the amount of data transfered per month so that I don't end up with a supprize bill one day :wink:
once I figure out how to manage that, then I will transfer every thing over to godaddy and we can enjoy the larger bandwidth :D
Cheers,
Corey
mfflynn
Post by mfflynn »
Thanks for getting the server back up! I did run into a problem when I updated though. After everything was downloaded and it began to install everything I got this error:
warning: rpmts_HdrFromFdno: V3 DSA signature: NOKEY, key ID 475c5926
public key not available for zm-1.21.4-0.4.fc.root.i386.rpm
Retrieving GPG key from ftp://download.computerntelecom.com/pub/RPM-GPG-KEY-CTU
Importing GPG key 0x475C5926 "RPM-GPG-KEY-CTU (Signature for CTU built packages) <packages@computerntelecom.com>"
Is this ok [y/N]: y
Key imported successfully
warning: rpmts_HdrFromFdno: V3 DSA signature: NOKEY, key ID 4f2a6fd2
public key not available for curl-7.12.3-4.fc3.i386.rpm
The GPG key at ftp://download.computerntelecom.com/pub/RPM-GPG-KEY-CTU (0x475C5926)
is already installed but is not the correct key for this package.
Check that this is the correct key for the "CTU Core 3 - i386 - Released Updates" repository.
Any ideas on what I can / should do about this?
jameswilson
I suppose you have raed this post and schecked all the key info mentioned on the previous pages?
James Wilson
cordel
Post by cordel »
Curl is a fedora built package and requires the Fedora key:
rpm --import http://download.fedora.redhat.com/pub/f ... KEY-fedora
I will fix this in the next release.
Cheers,
Corey
mfflynn
Video options still not working
Post by mfflynn »
Ok, I have yet another question for you guys. (This time I searched first :) )
Before I was told that upgrading via yum would fix the video issues. (I.E. Trying to view the streams in video mode as opposed to jpeg and saving an event as video.) After upgrading from your server (thanks by the way) still none of the video options work? Any ideas on how to get that up and running?
jameswilson
that was me i thought that corey knew what was the issue with ffmpeg and ctu but maybe im wrong. YOu need to wait for the genius that is corey to answer im afraid as im obviously wrong!
James Wilson
cordel
Post by cordel »
I have made a new package zm-1.22.0-1.8 that corrects several issues and also is built on the ffmpeg cvs snapshot from 12-2005.
The web/update server is in a different location and I forgot the login info that I had setup for the ftp :oops:
I also have no video server setup to test with at the moment, so I might need a couple people to check it for me at the moment :roll:
Regards,
Corey
jameswilson
I can power up my ctu box if you need me to test it mate
James Wilson
cordel
Post by cordel »
Hi James,
Emailed you the packages :D
Thank you,
Corey
jameswilson
ill plug it in shortly mate and let you know!
James Wilson
