[SOLVED] Lost config with distro and zm version upgrade
cookiemonster
Re: Lost config with distro and zm version upgrade
Post by cookiemonster »
Permissions are all correct with www-data as owner (this is Ubuntu) with the exception of /usr/lib/zoneminder/cgi-bin/ that is owned by root. That is OK though, the zms binary inside is working for creating the recordings.
The link from conf-available to conf-enabled is normal. What happens is that you create your websites in available and then can use a2ensite utility from apache that creates the link to enabled. Ubuntu seems to use sites-available & sites-enabled but the way to enable them is the same.
Now back to the problem, I'm convinced it is a problem I have in apache, note the screenshot says the 404s are when trying to show http://192.168.5.176/zm/cgi-bin/nph-zms ... 1745590306. The last digit seems a random number and the rest is apache trying the script alias i.e. nph-zms that is a symlink to zms. BUT I can see the recordings in the UI (perms are OK therefore).
I'll see what else I can spot in the apache config differences but remembering I'm ubuntu you're debian I think, and what iconnor has said what it should be.
This is mine:
<VirtualHost *:80>
    ServerAdmin webmaster@localhost
    DocumentRoot "/usr/share/zoneminder/www"
    Alias /zm/cache "/var/cache/zoneminder/cache"
#    Alias /zm/cache "/var/cache/zoneminder"
#    Alias /zm/cache "/mnt/Surveillance/zoneminder"
    <Directory "/var/cache/zoneminder/cache">
#    <Directory "/var/cache/zoneminder">
#    <Directory "/mnt/Surveillance/zoneminder">
#        AllowOverride None
        AllowOverride All
        <IfModule mod_authz_core.c>
           # Apache 2.4
           Require all granted
        </IfModule>
        <IfModule !mod_authz_core.c>
            # Apache 2.2
            Order deny,allow
            Allow from all
        </IfModule>
    </Directory>
    Alias /zm "/usr/share/zoneminder/www"
    <Directory "/usr/share/zoneminder/www">
        AllowOverride All
        Require all granted
           # Apache 2.4
           Require all granted
        </IfModule>
            # Apache 2.2
            Order deny,allow
            Allow from all
        </IfModule>
    </Directory>
#    ScriptAlias /cgi-bin "/usr/lib/zoneminder/cgi-bin"
    ScriptAlias /zm/cgi-bin "/usr/lib/zoneminder/cgi-bin/"
        AllowOverride All
           # Apache 2.4
           Require all granted
        </IfModule>
            # Apache 2.2
            Order deny,allow
            Allow from all
        </IfModule>
    </Directory>
       RewriteEngine on
       RewriteBase /zm/api
    </Directory>
       RewriteEngine on
       RewriteRule ^$ webroot/ [L]
       RewriteBase /zm/api
    </Directory>
        RewriteEngine On
        RewriteRule ^ index.php [L]
        RewriteBase /zm/api
    </Directory>
    # Use the first option to have Apache logs written to the general log
    # directory, or the second to have them written to the regular Apache
    # directory (you may have to change the path to that used on your system)
    ErrorLog /var/log/zm/apache-error.log
    #ErrorLog /var/log/httpd/zm-error.log
    # Possible values include: debug, info, notice, warn, error, crit,
    # alert, emerg.
    LogLevel warn
    CustomLog /var/log/zm/apache-access.log combined
    #CustomLog /var/log/httpd/zm-access.log combined
</VirtualHost>
Really appreciate the help. The head scratching continues.
cookiemonster
adam.robertson wrote: Sat Apr 26, 2025 2:41 pm I deleted the ZM config because I just use the apache sites-enabled with my config file there:
###MY sites-enabled config file...keep in my mind I have my ZM on the root path rather than using http://mysite/zm/
## so my ScriptAlias are going to NOT have /zm/ in front. <== THIS GAVE ME An IDEA
As well as your config where the ScriptAlias is before the paths Aliases
<VirtualHost *:80>
	ServerAdmin myzm@adminemail.com
	ServerName myzm.domain.name
        DocumentRoot /usr/share/zoneminder/www
   AllowOverride All
   Require all granted
</Directory>
   Alias /cache "/var/cache/zoneminder/cache"
        AllowOverride All
           Require all granted
        </IfModule>
    </Directory>
   <IfModule mod_dir.c>
     DirectoryIndex index.php
   </IfModule>
 </Directory>
  RewriteEngine on
  RewriteBase /api
</Directory>
  RewriteEngine on
  RewriteBase /api
</Directory>
   RewriteEngine On
   RewriteBase /api
</Directory>
 ErrorLog ${APACHE_LOG_DIR}/zm.domain.com_error.log
 CustomLog ${APACHE_LOG_DIR}/zm.domain.com_access.log combined
</VirtualHost>
And then read apache's modalias documentation for order of processing.
So from the config I have where they are:
1- # Order matters. This alias must come first.
2- Alias /zm "/usr/share/zoneminder/www"
3- ScriptAlias /zm/cgi-bin "/usr/lib/zoneminder/cgi-bin/"
It made me think that #3 /zm/ci-bin will never be reached as it has been redirected by #2 /zm before it. So I put #3 at the top.
Hunch was correct. Now all is good.
I'll mark it as solved.
Thank you very much for the help. I'm leaving this for those that come to search for it later.
p.s. - I did not put them in the wrong order. I took the apache example in /usr/share/doc/zoneminder/examples/apache.conf
adam.robertson
Re: [SOLVED] Lost config with distro and zm version upgrade
Post by adam.robertson »
Very cool. Your persistence is admirable. It took me about a week to get ZM fully working, then another week to figure out how to get zones working.
cookiemonster
Thank you.
I spent so much time and effort before to do the zones and settings for motion detection that I could never get right. In the end I pretty much gave up. Since then cameras are on mocord. I need to get a larger disk to keep more events though.
My main problem is very variable weather, a road in front and bushes.
adam.robertson
My issues were my wife's wind-chimes, bugs flying around the cameras at night, and random rain.
I have motion detection on all the cameras using the main stream - that view at low-resolution but record at high resolution, and then I use the low-res stream to constant record to a different hard-drive at low-res.
It is not a perfect system, but it works and gives me events on one drive and a constant stream I can view if needed.
..but ZM is very new to me and I am guessing I will tweak it quite a bit at time goes on.
