Broken timeline view
migo
Re: Broken timeline view
Post by migo »
IgorA100 wrote: Tue Apr 15, 2025 7:40 am Have you cleared your browser cache?
Just now and after clear cookies and site data in FF fix doesn't work at all! :shock: Blank screen on every navigate back action... :( aaahh :( sorry for that.
IgorA100
Post by IgorA100 »
In FF version 115.22.0esr 64bit I can't reproduce this problem :(
migo
Post by migo »
I believe you, installing firefox-esr-bin 128.9.0-1 now, will see if it works there...
migo
Post by migo »
It worked only for first time clicking back button, after that all back actions ends with blank screen... IDK... :(
Screenshot From 2025-04-15 11-03-32.png (127.31 KiB) Viewed 15798 times
IgorA100
Post by IgorA100 »
migo wrote: Tue Apr 15, 2025 9:03 am after that all back actions ends with blank screen
After pressing "Back" for the first time we get to the console, I don't know where and how to press "back" for the second time.
I need step-by-step instructions to reproduce the problem.
migo
Post by migo »
I'm sorry for confusion caused. Second time I mean go to the next monitor/or the same and pres back. Than I get blank screen for all subsequent similar actions.
IgorA100
Post by IgorA100 »
I can't reproduce the problem :(
Have you checked it under Windows?
IgorA100
Post by IgorA100 »
FF 137.0.1 64bit also can't reproduce the problem.
migo
Post by migo »
IgorA100 wrote: Tue Apr 15, 2025 10:33 am I can't reproduce the problem :(
Linux only. Will find some wind machine and check...
migo
Post by migo »
Tested with windows, and I can reproduce this issue on default configured FF in Windows 2022 server. This site was never opened on this system, it was for the first time.
Screenshot From 2025-04-15 14-43-59.png (103.38 KiB) Viewed 15349 times
IgorA100
Post by IgorA100 »
I don't know what to do yet, because I still can't reproduce the problem :(
migo
Post by migo »
IgorA100 wrote: Tue Apr 15, 2025 2:42 pm I don't know what to do yet, because I still can't reproduce the problem :(
Thank you very much for trying. I can make video/screen recording of this issue, but that will not help to reproduce this issue on your side. :( There must be some difference in system/language/region that makes this difference.
IgorA100
Post by IgorA100 »
Maybe someone else will encounter this problem and there will be more information...
Maybe I will be able to reproduce this problem later...
I will try to remember about it...
migo
Post by migo »
Thank you, there must be some other factor affecting this issue, because sometime it works and displays console after pressing back and sometime not. Strange...
