Any current zoneminder 1.37 builds for fedora?
Re: Any current zoneminder 1.37 builds for fedora?
Yup he found a moment.
marklg
Post by marklg »
I tried building for F39 and F40 using mock from the F40 SRPM and it has the missing library issues:
-- Optional libraries found: zlib cURL OpenSSL PCRE libVLC
-- Optional libraries not found: Mosquitto Mosquittopp libVNC gsoap
I think the patch I included in my earlier post in this thread is required. Has anyone successfully used the new builds with ONVIF?
Regards,
Mark
I have applied your patch, we will see how it goes.
marklg
Post by marklg »
I built F39 rpms from zoneminder-1.37.65-1.126.20250208gitgfae724a2c.fc40.src.rpm using mock and it seems to work. UI is working and shows 1.37.65 as the version.
Upgraded computer to F41 and seems to work too with F41 rpms. I did have to reboot some cameras to get ONVIF subscriptions again.
I'm calling it a success so far.
Regards,
Mark
