Why is ZMES skipping Events !Solved!
lucas_nz
Re: Why is ZMES skipping Events !Solved!
Post by lucas_nz »
I'm not sure if it's a good idea to reopen this thread. I've noticed short events are sometimes missed on my zmes set up. This (https://zmeventnotification.readthedocs ... ered-in-zm) section suggests extending the post event buffer. Mine is set to 100 @4fps, that's 25 seconds, so should easily be caught. BUT (after adding some additional logging to zmeventnotification.log, I've noticed these short events go to state 4 ( = STATE_TAPE ??? ).
Having a play around, it seems that if I put the monitor into Record or Mocord, then the monitor is in state 5.
The plot thickens, it seems the state constants in perl don't match zoneminder:
https://github.com/ZoneMinder/zoneminde ... mory.pm.in
use constant STATE_UNKNOWN  => 0;
use constant STATE_IDLE     => 1;
use constant STATE_PREALARM => 2;
use constant STATE_ALARM    => 3;
use constant STATE_ALERT    => 4;
use constant STATE_TAPE     => 5;
cat test.pl
#!/usr/bin/perl  -T
use ZoneMinder;
print "STATE_UNKNOWN " . STATE_UNKNOWN . "\n";
print "STATE_IDLE " . STATE_IDLE . "\n";
print "STATE_PREALARM " . STATE_PREALARM . "\n";
print "STATE_ALARM " . STATE_ALARM . "\n";
print "STATE_ALERT " . STATE_ALERT . "\n";
print "STATE_TAPE " . STATE_TAPE . "\n";
./test.pl
STATE_UNKNOWN STATE_UNKNOWN
STATE_IDLE 0
STATE_PREALARM 1
STATE_ALARM 2
STATE_ALERT 3
STATE_TAPE 4
It seems there is a bug with the constants in perl - does that means this is a zoneminder bug rather than zmes? For now I've changed line 1406 of zmeventnotification.pl to:
    if ($state == STATE_ALARM || $state == STATE_ALERT || $state == 4) {
This is kindof a big problem. Used to be that STATE_UNKNOWN was -1. This is a problem, because I wanted to use the value to index into an array of strings to print out the state. So Unknown became 0. The problem is I did this in the middle of a stable series. Bad me.
So in 1.36.26, in terms of the API, we now hack the value back to where it should be by subtracting -1.
In perl land... yeah we never defined STATE_UNKNOWN and the values are wrong. I will fix this in 1.36.27 which should be released maybe tomorrow or monday.
If anyone would like to try out the fix early, please use the proposed ppa. You should get something reporting as 1.36.27.
lucas_nz
Post by lucas_nz »
I've upgraded and done some simple checks. Seems to be working correctly again :)
