Video won't load
fish2222
Re: Video won't load
Post by fish2222 »
I just tried to create a new camera, which created a new monitor #, and then added the same camera. Same thing. Is there a way to change the monitor number? I can't find it if there is.
Right after you clone it. a box above Name. It may not work well in 1.36, though. I mostly use 1.37. But I wouldn't go there just for that if I were you, 'cause it gets broken from time to time.
But once it's saved, no you can't change it, sorry.
fish2222
Post by fish2222 »
I still haven't figuredo out a fix for this, and now, another camera has the same issue. Also, if I used the H.265 codec with the one camera that I do have that only has H.265 in settings, I get the black box with an X in it for recording playback. If I use H.264 instead, it sometimes works, and sometimes just gets a blank screen with no playback.
fish2222
Post by fish2222 »
This is from the same camera. It seems to be starting new events before it finished old events.
shed cam.JPG (87.45 KiB) Viewed 889 times
I guess you need to timestamp this. Still, what happens if you use passthrough?
If you have empty endtime, you have crashing. Look at your logs.
