Why is rows per page up to 200 and then all
Re: Why is rows per page up to 200 and then all
I think having several options is worth having rather than the old one where you had to go to options to make a change so the general principle is good. However adding the facility to set your own values would be very helpful.
Following a previous comment about deleting files from disc, that is what I did yesterday as I have over 2000 to remove. I have zmaudit running but it had not tidied up the database and I had to run it from a command prompt to remove the database entries.
- knight-of-ni
We recommend running zmaudit from a cron job, rather than enabling it in the web options.
Thank you for that little nugget. I'll move zmaudit to cron.
