[solved] Hikvision DS-KB8112-IM connection to ZM?
DonZalmrol
Re: Hikvision DS-KB8112-IM connection to ZM?
Post by DonZalmrol »
Its a virtual headless server, so I will not be able to display an output.
But I will try this tonight, perhaps it display some more information about the stream.
On my computer it open without any issues besides the previous mentioned error messages.
Mine's an AM, but otherwise similar. It's more about reading the text when it fails.
Some cameras don't do tcp. Try udp.
DonZalmrol
When I run it from my server I get this message:
[NULL @ 0x555b4e1ce8c0] Unable to find a suitable output format for 'rtsp://username:password@ipaddress:554/h264/ch1/main/av_stream'
rtsp://username:password@ipaddress:554/h264/ch1/main/av_stream: Invalid argument
and if use ffplay:
root@GRE-MAN-02:/usr/bin# ffplay -i rtsp://username:password@ipaddress:554/h264/ch1/main/av_stream': Invalid argument
ffplay version 4.1.6-1~deb10u1 Copyright (c) 2003-2020 the FFmpeg developers
  built with gcc 8 (Debian 8.3.0-6)
  configuration: --prefix=/usr --extra-version='1~deb10u1' --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
  libavutil      56. 22.100 / 56. 22.100
  libavcodec     58. 35.100 / 58. 35.100
  libavformat    58. 20.100 / 58. 20.100
  libavdevice    58.  5.100 / 58.  5.100
  libavfilter     7. 40.101 /  7. 40.101
  libavresample   4.  0.  0 /  4.  0.  0
  libswscale      5.  3.100 /  5.  3.100
  libswresample   3.  3.100 /  3.  3.100
  libpostproc    55.  3.100 / 55.  3.100
Argument 'Invalid' provided as input filename, but 'rtsp://username:password@ipaddress:554/h264/ch1/main/av_stream':' was already specified.
Don't think its due to TCP vs UDP, tried changing the setting before and it didn't do much else...
Sounds like you need to put the RTSP part in quotes.
DonZalmrol
Ok, stupid of me. It was indeed the quotes.
Now I get a different error with ffplay:
Could not initialize SDL - No available video device
(Did you set the DISPLAY variable?)
But that could be due to the fact its a headless server (no physical monitor, its a virtual machine).
After testing yesterday I've build a new server and set it up.
Same issue persists. I'm starting to believe that these door stations from HikVision don't use the proper RTSP stream settings/ protocol.
Now my Zoneminder is giving me this error
Unable to open input rtsp://username:password@ipaddress:554/h264/ch1/main/av_stream due to: Invalid data found when processing input
Same error occurs when you run the command on the server via ssh directly.
root@hostname:/home/administrator# ffmpeg -i "rtsp://username:password@ipaddress:554/h264/ch1/main/av_stream"
ffmpeg version 4.1.6-1~deb10u1 Copyright (c) 2000-2020 the FFmpeg developers
rtsp://username:password@ipaddress:554/h264/ch1/main/av_stream: Invalid data found when processing input
Ok.
I just run one of the other ff progs, such as ffprobe -i rather than ffplay (for the exact reasons you stated). ffmpeg -i works and of course stops with the error showing no output specified.
What this all suggests is it's an ffmpeg error that is just surfacing via ZM.
I'd go with running ffprobe, add a '-report' argument and then it'll create a file in the directory you run it from named ffprobe-DATE-TIME.log. Have a look for signs of trouble in there.
DonZalmrol
Ha when running the ffprobe I now get this error:
[rtsp @ xxx] method OPTIONS failed: 401 Unauthorized
rtsp://username:password@ipaddress:554/h264/ch1/main/av_stream: Server returned 401 Unauthorized (authorization failed)
The virtual server is in the same vlan as the camera's so you couldn't say its being blocked by my firewall.
Also if it would be blocked by the firewall the other cams shouldn't work neither since these also use RTSP...
EDIT:
The FFProbe did returned a log:
ffprobe started on 2020-10-09 at 13:45:18
Report written to "ffprobe-20201009-134518.log"
Command line:
ffprobe -rtsp_transport tcp rtsp://username:password@ipaddress:554/h264/ch1/main/av_stream -report
ffprobe version 4.1.6-1~deb10u1 Copyright (c) 2007-2020 the FFmpeg developers
  configuration: --prefix=/usr --extra-version='1~deb10u1' --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enab$
[tcp @ xxx] No default whitelist set
[tcp @ xxx] Original list of addresses:
[tcp @ xxx] Address ipaddress port 554
[tcp @ xxx] Interleaved list of addresses:
[tcp @ xxx] Starting connection attempt to ipaddress port 554
[tcp @ xxx] Successfully connected to ipaddress port 554
[rtsp @ xxx] CSeq: 2
WWW-Authenticate: Digest realm="TIGERYIN", nonce="xxx", random="xxx", stale="FALSE"
WWW-Authenticate: Basic realm="/"
rrtsp://username:password@ipaddress:554/h264/ch1/main/av_stream: Server returned 401 Unauthorized (authorization failed)
So it connects to the door station, but then fails when it gets to the OPTIONS part.
DonZalmrol
Re: Hikvision DS-KB8112-IM connection to ZM? -Resolved-
Found the issue!!!
It was due to the password I've used, seems that the encoding messes up passwords with special characters...
Example from someone else who had it: https://stackoverflow.com/questions/589 ... ing-opencv
So I'm wondering if we should be translating %'s into %25's when passing the url to ffmpeg..
Kinda annoying
Good to see you've made progress with it.
DonZalmrol
Well I had a different character then the '%' sign.
Suffice to say certain characters will/ could break the URL.
e.g. '@', '%', ...
Not sure if these are "fixable". Anyway its resolved :)
Good. Means I can safely add the doorbell to my Xmas list. :-)
