I need help getting audio recording to work
user671
Re: I need help getting audio recording to work
Post by user671 »
burger wrote: Thu Jun 11, 2020 3:00 am GPU isn't used by ZM (except by advanced users).
If you need lower load on 4K cameras see: viewtopic.php?f=9&t=27537
Wait what does the hardware acceleration option do then?
https://imgur.com/a/37XBOZp
I thought that was for GPUs to offset some of the workload
burger
Post by burger »
From the reports on the forum, performance of graphics cards is mixed atm. It's new & WIP. Advanced users only.
First upgrade the CPU / motherboard.
fastest way to test streams:
user671
Post by user671 »
burger wrote: Fri Jun 12, 2020 2:07 pm From the reports on the forum, performance of graphics cards is mixed atm. It's new & WIP. Advanced users only.
So the performance gains from using the hardware acceleration option are not significant, but there are performance gains from using that option right?
I currently have a GPU in that pc and it seems like a waste to have it doing nothing at all. Even if the gains aren't great I'd still like to do it. I just have this problem whenever I try. The logs will say something along the lines of hardware acceleration device not found...
jrey36
Post by jrey36 »
Adding to the end of the source url ":1" fixed audio for me with Tapo (TP-Link) cameras (C120 model) on a Raspberry Pi 5.
User, Pedulla, suggested running this command "ffmpeg -i rtsp://user:password@camIP:554/Streaming/Channels/101 -c:v copy -c:a aac foo.mp4" in terminal to get more details on the url. Mine had suggested 0:0, 0:1
The default stream for my cam ends with "stream1" I just added ":1" to the end. You will need to run the command to get the details for your cameras.
