Zoneminder 1.33.X Debian 9
Re: Zoneminder 1.33.X Debian 9
New up to date packages should be available for jessie, stretch, sid, buster
Install procedure on the WIKI:
https://wiki.zoneminder.com/Debian_10_B ... pro_Master
Developed on Buster AMD64 but should work for other Debian versions by changing the /etc/apt/sources.list
For Buster: deb https://zmrepo.zoneminder.com/debian/master buster/
For Stretch: deb https://zmrepo.zoneminder.com/debian/master stretch/
For Jessie: deb https://zmrepo.zoneminder.com/debian/master jessie/
pgrunwald
Post by pgrunwald »
Would you recommend that I update to from 1.32.3 to 1.33.x on Stretch first or update to Buster first, then upgrade to 1.33.x?
(yes, I know a clean Buster install would be better...)
benoit34
Post by benoit34 »
Hi, thanks for the package of 1.33.14 on Debian ! I've just test it.
Running on buster fresh install, following your instructions install, I have an issue with the filter page.
/zm/index.php?view=filter is fine,
but /zm/index.php?view=filter&Id=1 (and even 2) gave a blank page.... Did I miss anything ? Or is it a known bug ?
Thanks for the good job !
Regards
cristol
Post by cristol »
Hi Benoit34 (Salut) :D
try it :
mysql -u zmuser -p zm < /usr/share/zoneminder/db/zm_update-1.33.14.sql
Password is zmpass.
Source : http://forums.zoneminder.com/viewtopic. ... 9&p=111910
benoit34
Post by benoit34 »
Great ! Thanks a lot !
I missed this thread !
Works perfectly !
Merci Cristol !
cristol
Post by cristol »
Avec plaisir :)
