After upgrade to 1.29, crashing daily
AndresCT46
Re: After upgrade to 1.29, crashing daily
Post by AndresCT46 »
Goodnight
I attach the error log ZoneMinder
thanks
zm-log.html.zip
(4.53 KiB) Downloaded 214 times
Lieuwke
Post by Lieuwke »
I have subscribed to this topic since i am encountering the same problems.
Soljia
Post by Soljia »
I'm not providing any solutions, but just what I've observed so far on my particular issue with daily crashes.
I'm not sure if I'm getting the same thing, but I also upgraded from 1.28 to 1.29. The resource savings is very nice. I also get crashes almost daily. However, I have noticed, that it's only when I load the web interface. I'll immediately start it again, and it works fine. I also noticed that it doesn't crash before I log in, as all the event from before that specific time are there. I also believe that I checked via "service zoneminder status" before I logged into the web interface and it showed as stopped. This leads me to believe that ZM is still functioning correctly, it's just not getting it's status correctly. I will checked via top (I like htop), next time this happens to confirm if any zmc processes are live. Additionally, I've checked the syslog and all zm logs, and only issue I can find is a very seldom buffer overrun and what seems to be a shared memory error. My /run/shm was at 86%, so I increased it size in the mean time to test that.
Update: So, it did it's "crash" again. I checked htop, and the ZMC instances are still running. However, the web interface and "service zoneminder status" both show as stopped. After I started zoneminder again, the zmc instances were killed and relaunched. Image
