EasyN FS-613B-M166 IP PTZ camera
2Psycho
Re: EasyN FS-613B-M166 IP PTZ camera
Post by 2Psycho »
Therese,
I ment this file :D
So far I can see you have configured
#Up Arrow
sub moveConUp
my $self = shift;
$stop_command = “1?;
Debug( “Move Up” );
my $cmd = “decoder_control.cgi?command=0&user=admin&pwd=”;
$self->sendCmd( $cmd );
This should be in my opinion:
#Up Arrow
sub Up
my $self = shift;
Debug( “Move Up” );
Evenso the "Can Move Continuous" must be disabled.
When you have saved the file click several times on the button to test it.
Enjoyment Matters
therese
Post by therese »
changed the config file but still no response from the camera. Seems like the command is going no where it is not receiving it. :(
2Psycho
Post by 2Psycho »
Did you al ready treid if you can move the camera when you send this command straight from your browser.
Like this?
http://192.168.1.30:81/decoder_control. ... admin&pwd=
Enjoyment Matters
therese
Post by therese »
Yes with this command straight from the browser moved the camera up... :D
2Psycho
Post by 2Psycho »
Ok at least we know that the link is correct
Did you already check the your settings with my screenshot
Enjoyment Matters
therese
Post by therese »
yes I have checked your screen shot and also set it up the same way but still control unresponsive.
2Psycho
Post by 2Psycho »
I am getting out of ideas.. :cry:
But what you can check is if you have JSON installed
$ sudo apt-get install libjson-any-perl
Enjoyment Matters
therese
Post by therese »
Code:
Tried this & did load files and updated but still no response... :(
it keeps coming back with the same message every time.
"Control response was status = undefined message = /usr/bin/zmcontrol.pl --command=Up --id=5=>"
2Psycho
Post by 2Psycho »
Therese
I have created a new control file for the camera please check this one out and let me know
Erik
EasyN.zip
(2.18 KiB) Downloaded 263 times
Enjoyment Matters
therese
Post by therese »
Success !!!
Erik thank you for your help really appreciate everything you have done...great work.
Deleted the old EasyN.pm file and replaced the file you created, did not work at first then I noticed this....
# EasyN FS-613B-M166 IP Control Protocol
use Time::HiRes qw( usleep );
changed
use Zoneminder::Logger qw(:all);
to...
use Zoneminder::Debug qw(:all);
then it started to work... :D
but now have to figure how to stop it if I pan to left it will keep turning left and not stop till it gets to the end.
2Psycho
Post by 2Psycho »
Your Welcome
Just keep me posted on the progress and place your file here on the forum so you can share it with everyone 8)
Enjoyment Matters
therese
Post by therese »
Here is the modified EasyN config file ( EasyN FS-613B M166 IP PTZ Camera ) so far manage to control the pan, tilt function the reset function and also the Home preset buttons....enjoy :D
There is no diagonal control with these camera.
EasyN.zip
(2.15 KiB) Downloaded 248 times
therese
Post by therese »
Updated script to fix jerky motion when panning camera...
#Up Arrow
sub Up
my $self = shift;
Debug( "Move Up" );
my $cmd = "decoder_control.cgi?command=0&onestep=1&user=admin&pwd=";
#Down Arrow
sub Down
my $self = shift;
Debug( "Move Down" );
my $cmd = "decoder_control.cgi?command=2&onestep=3&user=admin&pwd=";
#Left Arrow
sub Left
my $self = shift;
Debug( "Move Left" );
my $cmd = "decoder_control.cgi?command=4&onestep=5&user=admin&pwd=";
#Right Arrow
sub Right
my $self = shift;
Debug( "Move Right" );
my $cmd = "decoder_control.cgi?command=6&onestep=7&user=admin&pwd=";
EasyN.pm.zip
(2.25 KiB) Downloaded 270 times
therese
Post by therese »
My settings on this camera...
stoneybroke
Post by stoneybroke »
I have recently bought a Foscam PTZ camera and have installed scripts from all over the place and I still can't get the camera to pan, tilt, zoom, or do anything else except show a picture and give me errors but I found a very useful add-on for Firefox below that shows the camera in the sidebar and allows you to control the camera so the problem is almost solved lol
https://addons.mozilla.org/en-US/firefo ... serprofile
*** Microsoft Windows ***
A compete waste of perfectly good space on a hard drive.
