D-Link 2630l no image displayed
girkers
Post by girkers » Wed Mar 22, 2017 10:40 am
Nice camera and I can get it working partially. Checking the D-Link compatibility list I follow these settings https://wiki.zoneminder.com/D-Link#DCS- ... d_DCS-2230 and I can get the camera partially working.
When I look at the Monitor I have set up it tells the me the State is Idle, I have approximate 15 frames per second which is what I have the camera set too and the Mode is Live. However it takes an externity before the picture actually displays and then it never seems to update.
I have run the windows ONVIF software and I can see the camera if I log into the ONVIF software, even though I have turned off HTTP and RSTP authentication in the camera. When going through the ONVIF software you can see a little snapshot of the camera, but when I go to Live Video it says "No Signal", the url it is using is the rstp link.
Any ideas or thoughts?
Cheers
Girkers
girkers
Re: D-Link 2630l no image displayed
Post by girkers » Fri Mar 24, 2017 12:36 am
I have had a little bit of success, I can now get the ONVIF software viewing the camera and also using VLC I can get an image using rtsp://192.168.254.220/play1.sdp
How do I translate either of these results into settings I can use in Zoneminder?
Cheers
Girkers
Girkers
Users browsing this forum: No registered users and 8 guests
