No row for frame
px03afk
No row for frame
Post by px03afk »
I've just found a bunch of errors in the log which come from web_php which read 'No row for Frame'. They seem to be transient and not causing any obvious issue. I was wondering what causes them.
Re: No row for frame
px03afk wrote:I've just found a bunch of errors in the log which come from web_php which read 'No row for Frame'. They seem to be transient and not causing any obvious issue. I was wondering what causes them.
Linux distro and version? Camera info? Instructions you used to install Zoneminder?
bb
viewtopic.php?f=36&t=24846
bb
px03afk
Post by px03afk »
Sorry, should have thought to provide that information. I am running ZM 1.30.2 on OpenSuse Leapwith Foscam FI8918W and FI8904W cameras. I always compile ZM from source.
On looking a little more at the errors I find that the pids are pointing at an httpd-prefork process and the apache error log is showing PHP Notice: Undefined property: Frame::$Id in /srv/www/htdocs/zoneminder/includes/Frame.php on line 73. Then I started looking even deeper and discovered that there was a Bot trying to access my ZM data and that was causing the error. Still not entirely sure what the error means but it did lead me to blocking a couple of rogue IP addresses.
how did you find the Bot? I have had some errors I have not seen before lately.
px03afk
Post by px03afk »
Because the pids in question were httpd-prefork I looked in the apache error log and that is where I saw reference to a Bot.
asker
Post by asker »
Is it possible to share the exact log?
Please read before posting:
ES docs
zmNinja docs
px03afk
Post by px03afk »
Turns out that this is a Russian search engine at yandex.com. Initially I blocked it by updating my web server but then I found that I could do it by URL in my router.
The error_log entries are of this form:
[Wed Mar 15 08:36:56.829043 2017] [php5:error] [pid 9755] [client 37.9.122.203:5 2712] ERR [No row for Frame ]
[Wed Mar 15 08:36:56.885169 2017] [php5:error] [pid 9755] [client 37.9.122.203:5 2712] PHP Notice: Undefined property: Frame::$Id in /srv/www/htdocs/zoneminder/includes/Frame.php on line 73
There are entries in the access_log which look like this:
37.9.122.203 - - [17/Mar/2017:15:30:25 +0000] "GET /robots.txt HTTP/1.1" 404 101 1 "-" "Mozilla/5.0 (compatible; YandexBot/3.0; +http://yandex.com/bots)"
37.9.122.203 - - [17/Mar/2017:15:30:29 +0000] "GET /zoneminder/?view=frames&eid=85843 HTTP/1.1" 200 2598 "-" "Mozilla/5.0 (compatible; YandexBot/3.0; +http://yandex.com/bots)"
asker
Post by asker »
Wow, so bots are exploiting some past known vulnerabilities of ZM!
If I recall correctly, this issue of people being able to bypass security and view event images was fixed a few months ago.
ES docs
zmNinja docs
px03afk
Post by px03afk »
Correction to my previous message, my router isn't blocking so I'm glad I set up apache to do it for me.
these are the errors that flooded my logs, then stopped... and just disappeared:
2017-03-09 10:55:39.090772   zms      20825   ERR   Can't open /tmp/zm/zmswap-m5/zmswap-q938775/zmswap-i00198.jpg: No such file or directory   zm_image.cpp   869
2017-03-09 10:55:38.842998   zms      20825   ERR   Can't open /tmp/zm/zmswap-m5/zmswap-q938775/zmswap-i00197.jpg: No such file or directory   zm_image.cpp   869
thousands of these errors flooded the logs and Backtrace errors with them mixed in.
I was told the zmswap-xxx files are created during event playback. The thing was there were no events present...I removed them prior to these errors appearing. I thought a 3rd party program reading the ZM stream was the cause...now I am not so sure.
In any case the errors stopped and I can not duplicate them as of yet.
