PacoLM wrote:If I'm not wrong webmin does exactly the same a terminnal will do...What's the difference between a webmin update and a terminal update when the executed command is the same?
That's the impression I was under as well.
So I did two machines upgrade from 1.29 to 1.30 both using exact same approach, one worked, one doesn't, but the machines are largely configured the same. I have not had time to attempt to do the upgrade via SSH, but I suspect I will wind up with same issue.
My point in this is to try to understand what caused the error "WARNING: The following packages cannot be authenticated! zoneminder zoneminder-doc" and how to fix that. I can get the thing upgraded, I am pretty confident...I am just trying to understand what
caused this error and how I would go about fixing it.
