Note that my first camera (a Foscam C1) is now working perfectly in zoneminder using ffmpeg, so there shouldn't be any underlying ZM or ffmpeg problems.
This is an Amcrest (which is foscam) Qcam IP2M822E. The closest I could find to what's in the list on the hardware guide (https://wiki.zoneminder.com/Amcrest_QCam). I think this is the same camera as that second one (the 2MP one), but in a different color.
The errors I'm getting are simply:
Unable to open input rtsp://admin:12345@192.168.1.16:554/realmonitor?channel=1&subtype=0 due to: Operation now in progress
I've tried now at different resolutions (1280x720 and 1920x1080, predominantly). I've set it to max of 10 FPS (the camera is set up to just use 8 frames per second though I also tried max of 30fps just in case it wasn't setting correctly and I tried with those left blank, but it went into buffer overrun analyzing the blue screen).
I've got it set up for RTP/RTSP
The camera is viewable using their qcam "SmartClient" software (which is what I used to set it to 8fps)
The source path I've tried is above, but I also tried without the username/pass (those don't appear changeable ... they're on a sticker on the camera and not configurable in SmartClient).
Any ideas what to try next?
