So to test zoneminder I loaded it on my laptop running Fedora 24. Sorta worked OK, so I decided to load it on a dedicated server.
Followed the Unbunt 14.04 instructions on the wiki. Install went flawlessly. Opened web page to the server and low and behold the "LOG" icon in upper right is red. HMMM so I check it our and here is what I am getting. Unfortunately these are not very descriptive to me, so maybe a more knowledgeable guru can figure whats wrong. Thanks in advance.
2016-08-28 17:39:53.436323 web_js 1436 ERR TypeError: e[c] is undefined http://192.168.10.77/zm/tools/mootools/mootools-more.js 1
2016-08-28 17:39:53.103925 web_js 1436 ERR TypeError: e[c] is undefined http://192.168.10.77/zm/tools/mootools/mootools-more.js 1
2016-08-28 17:38:27.099110 zmdc 1303 INF 'zmc -m 1' exited normally zmdc.pl
2016-08-28 17:38:27.063375 zmc_m1 1338 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-28 17:38:27.055754 zmc_m1 1338 ERR Unable to read subheader zm_remote_camera_http.cpp 977
2016-08-28 17:38:27.049022 zmc_m1 1338 ERR Select error: Interrupted system call zm_remote_camera_http.cpp 175
2016-08-28 17:38:27.042761 zmc_m1 1338 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-08-28 17:38:27.037250 zmdc 1303 INF 'zmc -m 1' sending stop to pid 1338 at 16/08/28 17:38:27 zmdc.pl
2016-08-28 17:38:26.888350 zmdc 1303 WAR Can't find process with command of 'zma -m 1' zmdc.pl
2016-08-28 17:38:19.855972 web_php 1436 ERR socket_sendto( /var/run/zm/zms-040066s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:38:16.842195 web_js 1436 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-040066s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:38:16.805433 web_php 1436 ERR socket_sendto( /var/run/zm/zms-040066s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:37:55.811539 web_php 1575 ERR socket_sendto( /var/run/zm/zms-554333s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:37:52.799785 web_js 1575 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-554333s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:37:52.775789 web_php 1575 ERR socket_sendto( /var/run/zm/zms-554333s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:37:17.227962 zmc_m1 1338 INF FrontPorch: 5000 - Capturing at 12.82 fps zm_monitor.cpp 3116
2016-08-28 17:35:59.748370 zmc_m1 1338 INF FrontPorch: 4000 - Capturing at 14.29 fps zm_monitor.cpp 3116
2016-08-28 17:34:49.548401 zmc_m1 1338 INF FrontPorch: 3000 - Capturing at 14.08 fps zm_monitor.cpp 3116
2016-08-28 17:33:51.180512 web_js 1435 ERR TypeError: e[c] is undefined http://192.168.10.77/zm/tools/mootools/mootools-more.js 1
2016-08-28 17:33:43.650302 web_js 1435 ERR TypeError: e[c] is undefined http://192.168.10.77/zm/tools/mootools/mootools-more.js 1
2016-08-28 17:33:39.144097 web_js 1435 ERR TypeError: e[c] is undefined http://192.168.10.77/zm/tools/mootools/mootools-more.js 1
2016-08-28 17:33:38.605793 zmc_m1 1338 INF FrontPorch: 2000 - Capturing at 14.08 fps zm_monitor.cpp 3116
2016-08-28 17:32:59.143217 web_js 1435 ERR TypeError: e[c] is undefined http://192.168.10.77/zm/tools/mootools/mootools-more.js 1
2016-08-28 17:32:53.960786 web_js 1576 ERR TypeError: e[c] is undefined http://192.168.10.77/zm/tools/mootools/mootools-more.js 1
2016-08-28 17:32:27.919581 zmc_m1 1338 INF FrontPorch: 1000 - Capturing at 14.08 fps zm_monitor.cpp 3116
2016-08-28 17:32:11.522620 web_js 1575 ERR TypeError: e[c] is undefined http://192.168.10.77/zm/tools/mootools/mootools-more.js 1
2016-08-28 17:31:16.811230 zmdc 1373 INF 'zmtelemetry.pl' started at 16/08/28 17:31:16 zmdc.pl
2016-08-28 17:31:16.811220 zmdc 1303 INF 'zmtelemetry.pl' starting at 16/08/28 17:31:16, pid = 1373 zmdc.pl
2016-08-28 17:31:16.643840 zmdc 1303 INF 'zmupdate.pl -c' starting at 16/08/28 17:31:16, pid = 1366 zmdc.pl
2016-08-28 17:31:16.643820 zmdc 1366 INF 'zmupdate.pl -c' started at 16/08/28 17:31:16 zmdc.pl
2016-08-28 17:31:16.634280 zmwatch 1356 INF Watchdog pausing for 30 seconds zmwatch.pl
2016-08-28 17:31:16.626900 zmwatch 1356 INF Watchdog starting zmwatch.pl
2016-08-28 17:31:16.478510 zmdc 1356 INF 'zmwatch.pl' started at 16/08/28 17:31:16 zmdc.pl
2016-08-28 17:31:16.478370 zmdc 1303 INF 'zmwatch.pl' starting at 16/08/28 17:31:16, pid = 1356 zmdc.pl
2016-08-28 17:31:16.456970 zmfilter 1339 INF Scanning for events zmfilter.pl
2016-08-28 17:31:16.305740 zmdc 1348 INF 'zmaudit.pl -c' started at 16/08/28 17:31:16 zmdc.pl
2016-08-28 17:31:16.305740 zmdc 1303 INF 'zmaudit.pl -c' starting at 16/08/28 17:31:16, pid = 1348 zmdc.pl
2016-08-28 17:31:16.203140 zmc_m1 1338 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-08-28 17:31:16.132820 zmdc 1339 INF 'zmfilter.pl' started at 16/08/28 17:31:16 zmdc.pl
2016-08-28 17:31:16.132810 zmdc 1303 INF 'zmfilter.pl' starting at 16/08/28 17:31:16, pid = 1339 zmdc.pl
2016-08-28 17:31:16.122610 zmdc 1338 INF 'zmc -m 1' started at 16/08/28 17:31:16 zmdc.pl
2016-08-28 17:31:16.122600 zmdc 1303 INF 'zmc -m 1' starting at 16/08/28 17:31:16, pid = 1338 zmdc.pl
2016-08-28 17:31:16.114810 zmdc 1303 INF Starting pending process, zmc -m 1 zmdc.pl
2016-08-28 17:31:16.107160 zmdc 1303 ERR 'zmc -m 1' exited abnormally, exit status 255 zmdc.pl
2016-08-28 17:31:15.956420 zmdc 1303 INF 'zmc -m 1' starting at 16/08/28 17:31:15, pid = 1331 zmdc.pl
2016-08-28 17:31:15.956420 zmdc 1331 INF 'zmc -m 1' started at 16/08/28 17:31:15 zmdc.pl
2016-08-28 17:31:15.745270 zmpkg 1285 INF Single server configuration detected. Starting up services. zmpkg.pl
2016-08-28 17:31:12.740990 zmdc 1303 INF Server starting at 16/08/28 17:31:12 zmdc.pl
2016-08-28 17:31:12.411010 zmpkg 1285 INF Command: start zmpkg.pl
2016-08-28 17:31:12.399130 zmpkg 1285 INF Sanity checking States table... zmpkg.pl
2016-08-28 17:29:18.750385 zmc_m1 10003 INF FrontPorch: 1000 - Capturing at 14.08 fps zm_monitor.cpp 3116
2016-08-28 17:29:00.461936 web_php 9302 ERR socket_sendto( /var/run/zm/zms-203158s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:28:57.455250 web_js 9302 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-203158s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:28:57.421797 web_php 9290 ERR socket_sendto( /var/run/zm/zms-203158s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:28:54.483628 web_php 9656 ERR socket_sendto( /var/run/zm/zms-203158s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:28:54.408200 web_js 9302 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-203158w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-08-28 17:28:54.182771 web_php 9302 ERR socket_bind( /var/run/zm/zms-203158w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:28:51.549679 web_php 9730 ERR socket_sendto( /var/run/zm/zms-203158s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:28:51.445090 web_js 9302 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-203158w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-08-28 17:28:51.316180 web_php 9302 ERR socket_bind( /var/run/zm/zms-203158w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:28:48.115490 web_js 9302 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-203158s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:28:48.095604 web_php 9302 ERR socket_sendto( /var/run/zm/zms-203158s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:28:45.087075 web_js 9302 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-203158s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:28:45.055762 web_php 9302 ERR socket_sendto( /var/run/zm/zms-203158s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:28:20.305979 web_php 9293 ERR socket_sendto( /var/run/zm/zms-581093s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:28:19.646459 web_php 9301 ERR socket_bind( /var/run/zm/zms-581093w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:28:17.295595 web_js 9293 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-581093s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:28:17.245547 web_php 9293 ERR socket_sendto( /var/run/zm/zms-581093s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:28:14.236402 web_js 9293 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-581093s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:28:14.199304 web_php 9293 ERR socket_sendto( /var/run/zm/zms-581093s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:28:12.631427 web_php 9656 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:28:09.605795 web_js 9656 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:28:09.284592 web_php 9730 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:28:07.270800 zmdc 9021 WAR Can't find process with command of 'zma -m 1' zmdc.pl
2016-08-28 17:28:07.175540 zmc_m1 10003 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-08-28 17:28:07.103970 zmdc 10003 INF 'zmc -m 1' started at 16/08/28 17:28:07 zmdc.pl
2016-08-28 17:28:07.102190 zmdc 9021 INF 'zmc -m 1' starting at 16/08/28 17:28:07, pid = 10003 zmdc.pl
2016-08-28 17:28:06.939160 zmdc 9021 INF 'zmc -m 1' exited normally zmdc.pl
2016-08-28 17:28:06.909342 zmc_m1 9969 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-28 17:28:06.904551 zmc_m1 9969 ERR Unable to read content zm_remote_camera_http.cpp 1026
2016-08-28 17:28:06.901184 zmc_m1 9969 ERR Select error: Interrupted system call zm_remote_camera_http.cpp 175
2016-08-28 17:28:06.896125 zmc_m1 9969 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-08-28 17:28:06.888280 zmdc 9021 INF 'zmc -m 1' sending stop to pid 9969 at 16/08/28 17:28:06 zmdc.pl
2016-08-28 17:28:06.735960 zmdc 9021 WAR Can't find process with command of 'zma -m 1' zmdc.pl
2016-08-28 17:28:06.049451 web_php 9354 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:28:05.838123 web_js 9302 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-08-28 17:28:05.790329 web_php 9302 ERR socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:28:03.040754 web_js 9354 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:28:02.820251 web_php 9354 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:28:00.003068 web_php 9420 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:59.810996 web_js 9354 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-08-28 17:27:59.788089 web_php 9354 ERR socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:57.992530 zmdc 9021 WAR Can't find process with command of 'zma -m 1' zmdc.pl
2016-08-28 17:27:57.891712 zmc_m1 9969 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-08-28 17:27:57.834210 zmdc 9021 INF 'zmc -m 1' starting at 16/08/28 17:27:57, pid = 9969 zmdc.pl
2016-08-28 17:27:57.832840 zmdc 9969 INF 'zmc -m 1' started at 16/08/28 17:27:57 zmdc.pl
2016-08-28 17:27:57.671760 zmdc 9021 INF 'zmc -m 1' exited normally zmdc.pl
2016-08-28 17:27:57.639449 zmc_m1 9907 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-28 17:27:57.632956 zmc_m1 9907 ERR Unable to read subheader zm_remote_camera_http.cpp 977
2016-08-28 17:27:57.627947 zmc_m1 9907 ERR Select error: Interrupted system call zm_remote_camera_http.cpp 175
2016-08-28 17:27:57.617719 zmc_m1 9907 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-08-28 17:27:57.612190 zmdc 9021 INF 'zmc -m 1' sending stop to pid 9907 at 16/08/28 17:27:57 zmdc.pl
2016-08-28 17:27:57.463290 zmdc 9021 WAR Can't find process with command of 'zma -m 1' zmdc.pl
2016-08-28 17:27:56.887624 web_js 9420 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:27:56.862279 web_php 9290 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:54.282817 web_php 9301 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:53.842260 web_js 9290 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-08-28 17:27:53.803390 web_php 9290 ERR socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:50.948357 web_js 9301 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:27:50.848494 web_php 9290 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:47.870476 web_php 9293 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:47.838168 web_js 9301 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-08-28 17:27:47.804594 web_php 9301 ERR socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:44.864424 web_js 9293 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:27:44.837151 web_php 9301 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:42.156346 web_php 9656 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:41.829566 web_js 9301 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-08-28 17:27:41.793615 web_php 9301 ERR socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:39.148336 web_js 9656 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:27:38.891413 web_php 9656 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:35.885048 web_php 9730 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:35.826683 web_js 9656 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-08-28 17:27:35.793647 web_php 9656 ERR socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:32.872135 web_js 9730 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:27:32.832358 web_php 9730 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:29.865874 web_php 9926 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:29.816828 web_js 9730 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-08-28 17:27:29.797683 web_php 9730 ERR socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:26.860310 web_js 9926 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:27:26.833945 web_php 9730 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:23.905129 web_php 9291 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:23.844164 web_js 9532 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-08-28 17:27:23.786311 web_php 9730 ERR socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:20.903545 web_js 9291 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:27:20.863139 web_php 9730 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:18.095632 web_php 9354 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:17.856562 web_js 9730 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-08-28 17:27:17.798024 web_php 9730 ERR socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:15.061337 web_js 9354 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:27:15.016958 web_php 9354 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:11.989871 web_js 9354 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-08-28 17:27:11.868702 web_php 9302 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:11.804216 web_php 9354 ERR socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:08.852133 web_js 9302 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:27:08.830884 web_php 9302 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:05.890209 web_php 9420 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:05.818803 web_js 9302 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-08-28 17:27:05.797488 web_php 9302 ERR socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:27:02.877755 web_js 9420 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:27:02.830983 web_php 9302 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:59.935946 web_php 9290 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:59.814798 web_js 9302 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-08-28 17:26:59.794905 web_php 9302 ERR socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:59.778993 zmc_m1 9907 INF FrontPorch: 1000 - Capturing at 13.70 fps zm_monitor.cpp 3116
2016-08-28 17:26:56.919035 web_js 9290 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:26:56.866458 web_php 9302 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:54.099739 web_php 9293 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:53.845028 web_js 9302 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-08-28 17:26:53.800371 web_php 9302 ERR socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:50.964816 web_js 9293 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:26:50.898353 web_php 9293 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:48.240029 web_php 9656 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:47.833936 web_js 9301 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-08-28 17:26:47.801564 web_php 9301 ERR socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:45.178631 web_js 9656 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:26:45.161325 web_php 9293 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:42.080821 web_js 9293 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-08-28 17:26:41.947293 web_php 9926 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:41.849306 web_php 9293 ERR socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:38.959905 web_js 9926 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:26:38.916827 web_php 9926 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:36.026125 web_php 9532 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:35.902284 web_js 9926 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-08-28 17:26:35.785317 web_php 9926 ERR socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:33.025201 web_js 9532 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:26:33.000245 web_php 9926 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:29.983724 web_js 9926 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-08-28 17:26:29.878066 web_php 9291 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:29.793578 web_php 9926 ERR socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:26.864812 web_js 9291 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:26:26.833058 web_php 9291 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:23.879608 web_php 9730 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:23.818047 web_js 9291 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-08-28 17:26:23.796084 web_php 9291 ERR socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:20.863727 web_js 9730 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:26:20.829141 web_php 9291 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:18.061276 web_php 9354 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:17.819714 web_js 9291 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-08-28 17:26:17.798358 web_php 9291 ERR socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:14.884060 web_js 9354 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:26:14.843088 web_php 9354 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:12.000318 web_php 9420 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:11.831695 web_js 9354 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-08-28 17:26:11.792920 web_php 9354 ERR socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:08.994108 web_js 9420 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-08-28 17:26:08.951524 web_php 9420 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:06.703910 web_php 9290 ERR socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:05.817929 web_js 9420 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2016-08-28 17:26:05.787435 web_php 9420 ERR socket_bind( /var/run/zm/zms-277132w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-28 17:26:03.384485 web_js 9290 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-277132s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
Thanks in advance.
New install not working (Started Over with Fedora)
Re: New install not working
What camera did you configure?
None. There are no cameras connected at this time. This is the log with nothing running except Zoneminder. Sorry I was wrong. I did have my camera connected. Its a D-Link DCS-942L. I followed the wiki hardware guide and matched that to what I have the camera set for. I can view the image using rtsp protocol through my browser. Zoneminder is sensing the camera because when I set it to modec it does generate events and I do get photos. I can view them in the events folder or by selecting stills from the monitor. But when I select the camera all I get is a white screen that "blinks" every few seconds. If I try to view events, all I get is a white screen and no action on the progress bar.
Very strange. I have the camera settings configured as follows.
Source Type: Remote
Remote Protocol: HTTp
Remote Methoc: Simple
Remote Host Name: <name>:<password>@<ip address>
any help appreciated.
Source Type: Remote
