Just trying to install zoneminder "zoneminder-1.30.0-3.el7.centos.x86_64 (zmrepo)" and got hit with a perl::data dependency error. Anyone experince this before? Some help would be much appreciated. I'm running CentOS 7
Tried looking around but to no avail.
--> Processing Dependency: perl(Data::Dump) for package: zoneminder-1.30.0-3.el7.centos.x86_64
--> Finished Dependency Resolution
Error: Package: zoneminder-1.30.0-3.el7.centos.x86_64 (zmrepo)
Requires: perl(Data::Dump)
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
[danesh@zoneminder01 tmp]$
perl-5.16.3-286.el7.x86_64
perl-Carp-1.26-244.el7.noarch
perl-constant-1.27-2.el7.noarch
perl-Data-Dumper-2.145-3.el7.x86_64
perl-Data-UUID-1.219-3.el7.x86_64
perl-Digest-1.17-245.el7.noarch
perl-Digest-MD5-2.52-3.el7.x86_64
perl-Encode-2.51-7.el7.x86_64
perl-Exporter-5.68-3.el7.noarch
perl-File-Path-2.09-2.el7.noarch
perl-File-Temp-0.23.01-3.el7.noarch
perl-Filter-1.49-3.el7.x86_64
perl-Getopt-Long-2.40-2.el7.noarch
perl-HTTP-Tiny-0.033-3.el7.noarch
perl-libs-5.16.3-286.el7.x86_64
perl-macros-5.16.3-286.el7.x86_64
perl-parent-0.225-244.el7.noarch
perl-PathTools-3.40-5.el7.x86_64
perl-Pod-Escapes-1.04-286.el7.noarch
perl-podlators-2.5.1-3.el7.noarch
perl-Pod-Perldoc-3.20-4.el7.noarch
perl-Pod-Simple-3.28-4.el7.noarch
perl-Pod-Usage-1.63-3.el7.noarch
perl-Scalar-List-Utils-1.27-248.el7.x86_64
perl-Socket-2.010-3.el7.x86_64
perl-Storable-2.45-3.el7.x86_64
perl-Text-ParseWords-3.29-4.el7.noarch
perl-threads-1.87-4.el7.x86_64
perl-threads-shared-1.43-6.el7.x86_64
perl-Time-HiRes-1.9725-3.el7.x86_64
