Having issues viewing streamed video. crash signal 10 in log
markusonfire
Post by markusonfire »
I've recently installed ZM 1.29.0 on my Raspberry Pi 1 B.
I can access the WebUI fine and have added my Foscam FI8910W as follows (Name, IP, Password changed to examples):
General
Server: None
Source Type: Remote
Function: Monitor
Activated: Y
Source
Remote Protocol: HTTP
Remote Method: Simple
Remote Host Name: 192.168.0.52
Remote Host Port: 80
Remote Host Path: videostream.cgi?user=joblo&pwd=ThePassword
Target colorspace: 24 bit color
Capture width (pixels): 640
Capture height (pixels): 480
When I try to view the monitor, it shows a blank pane with the "Broken image" icon in the upper-left.
If I browse to http://192.168.0.52/videostream.cgi?use ... hePassword from the pi, I can see the stream no problem.
Is someone able to help out?
I've checked the logs, and see the following:
Date/Time
Component	Server	PID	Level	Message	File	Line
2016-04-26 10:11:09.092630	zmdc		1196	INF	'zmc -m 4' crashed, signal 10	zmdc.pl
2016-04-26 10:11:08.762790	zmdc		1961	INF	'zmc -m 4' started at 16/04/26 10:11:08	zmdc.pl
2016-04-26 10:11:08.742060	zmdc		1196	INF	'zmc -m 4' starting at 16/04/26 10:11:08, pid = 1961	zmdc.pl
2016-04-26 10:11:03.574430	zmwatch		1327	INF	Restarting capture daemon for CameraTest, shared data not valid	zmwatch.pl
2016-04-26 10:11:03.547150	zmwatch		1327	ERR	Memory map file '/dev/shm/zm.mmap.4' does not exist. zmc might not be running.	zmwatch.pl
2016-04-26 10:11:00.814641	web_js		744	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2016-04-26 10:11:00.632168	web_php		744	ERR	socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2371
2016-04-26 10:10:53.996920	zmdc		1196	INF	'zmc -m 4' crashed, signal 10	zmdc.pl
2016-04-26 10:10:53.356350	zmdc		1956	INF	'zmc -m 4' started at 16/04/26 10:10:53	zmdc.pl
2016-04-26 10:10:53.325840	zmdc		1196	INF	'zmc -m 4' starting at 16/04/26 10:10:53, pid = 1956	zmdc.pl
2016-04-26 10:10:49.464070	zmwatch		1327	INF	Restarting capture daemon for CameraTest, shared data not valid	zmwatch.pl
2016-04-26 10:10:49.447750	zmwatch		1327	ERR	Memory map file '/dev/shm/zm.mmap.4' does not exist. zmc might not be running.	zmwatch.pl
2016-04-26 10:10:48.506836	web_js		749	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2016-04-26 10:10:48.328659	web_php		749	ERR	socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2371
2016-04-26 10:10:39.670670	zmdc		1196	INF	'zmc -m 4' crashed, signal 10	zmdc.pl
2016-04-26 10:10:39.326690	zmdc		1952	INF	'zmc -m 4' started at 16/04/26 10:10:39	zmdc.pl
2016-04-26 10:10:39.321440	zmdc		1196	INF	'zmc -m 4' starting at 16/04/26 10:10:39, pid = 1952	zmdc.pl
2016-04-26 10:10:36.458011	web_js		1498	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2016-04-26 10:10:36.062784	web_php		1498	ERR	socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2371
2016-04-26 10:10:33.255440	zmwatch		1327	INF	Restarting capture daemon for CameraTest, shared data not valid	zmwatch.pl
2016-04-26 10:10:33.239420	zmwatch		1327	ERR	Memory map file '/dev/shm/zm.mmap.4' does not exist. zmc might not be running.	zmwatch.pl
2016-04-26 10:10:23.857951	web_js		745	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2016-04-26 10:10:23.713120	zmdc		1196	INF	'zmc -m 4' crashed, signal 10	zmdc.pl
2016-04-26 10:10:23.085309	web_php		745	ERR	socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2371
2016-04-26 10:10:23.016490	zmdc		1948	INF	'zmc -m 4' started at 16/04/26 10:10:23	zmdc.pl
2016-04-26 10:10:22.996840	zmdc		1196	INF	'zmc -m 4' starting at 16/04/26 10:10:22, pid = 1948	zmdc.pl
2016-04-26 10:10:18.384020	zmwatch		1327	INF	Restarting capture daemon for CameraTest, shared data not valid	zmwatch.pl
2016-04-26 10:10:18.367120	zmwatch		1327	ERR	Memory map file '/dev/shm/zm.mmap.4' does not exist. zmc might not be running.	zmwatch.pl
2016-04-26 10:10:10.836798	web_js		1574	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2016-04-26 10:10:10.581881	web_php		1574	ERR	socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2371
2016-04-26 10:10:08.823620	zmdc		1196	INF	'zmc -m 4' crashed, signal 10	zmdc.pl
2016-04-26 10:10:08.108620	zmdc		1944	INF	'zmc -m 4' started at 16/04/26 10:10:08	zmdc.pl
2016-04-26 10:10:08.084690	zmdc		1196	INF	'zmc -m 4' starting at 16/04/26 10:10:08, pid = 1944	zmdc.pl
2016-04-26 10:09:59.198480	zmwatch		1327	INF	Restarting capture daemon for CameraTest, shared data not valid	zmwatch.pl
2016-04-26 10:09:59.177770	zmwatch		1327	ERR	Memory map file '/dev/shm/zm.mmap.4' does not exist. zmc might not be running.	zmwatch.pl
2016-04-26 10:09:58.201553	web_js		1499	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2016-04-26 10:09:57.949307	web_php		1499	ERR	socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2371
2016-04-26 10:09:49.641160	zmdc		1196	INF	'zmc -m 4' crashed, signal 10	zmdc.pl
2016-04-26 10:09:48.985960	zmdc		1927	INF	'zmc -m 4' started at 16/04/26 10:09:48	zmdc.pl
2016-04-26 10:09:48.962680	zmdc		1196	INF	'zmc -m 4' starting at 16/04/26 10:09:48, pid = 1927	zmdc.pl
2016-04-26 10:09:45.823310	zmwatch		1327	INF	Restarting capture daemon for CameraTest, shared data not valid	zmwatch.pl
2016-04-26 10:09:45.807190	zmwatch		1327	ERR	Memory map file '/dev/shm/zm.mmap.4' does not exist. zmc might not be running.	zmwatch.pl
2016-04-26 10:09:45.599238	web_js		749	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2016-04-26 10:09:45.439342	web_php		749	ERR	socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2371
2016-04-26 10:09:36.273280	zmdc		1196	INF	'zmc -m 4' crashed, signal 10	zmdc.pl
2016-04-26 10:09:35.602380	zmdc		1923	INF	'zmc -m 4' started at 16/04/26 10:09:35	zmdc.pl
2016-04-26 10:09:35.575860	zmdc		1196	INF	'zmc -m 4' starting at 16/04/26 10:09:35, pid = 1923	zmdc.pl
2016-04-26 10:09:33.606258	web_js		750	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2016-04-26 10:09:33.205859	web_php		750	ERR	socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2371
2016-04-26 10:09:30.648590	zmwatch		1327	INF	Restarting capture daemon for CameraTest, shared data not valid	zmwatch.pl
2016-04-26 10:09:30.630610	zmwatch		1327	ERR	Memory map file '/dev/shm/zm.mmap.4' does not exist. zmc might not be running.	zmwatch.pl
2016-04-26 10:09:21.236833	web_js		1500	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2016-04-26 10:09:21.113280	zmdc		1196	INF	'zmc -m 4' crashed, signal 10	zmdc.pl
2016-04-26 10:09:20.919404	web_php		1500	ERR	socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2371
2016-04-26 10:09:20.525350	zmdc		1919	INF	'zmc -m 4' started at 16/04/26 10:09:20	zmdc.pl
2016-04-26 10:09:20.502050	zmdc		1196	INF	'zmc -m 4' starting at 16/04/26 10:09:20, pid = 1919	zmdc.pl
2016-04-26 10:09:17.324820	zmwatch		1327	INF	Restarting capture daemon for CameraTest, shared data not valid	zmwatch.pl
2016-04-26 10:09:17.307160	zmwatch		1327	ERR	Memory map file '/dev/shm/zm.mmap.4' does not exist. zmc might not be running.	zmwatch.pl
2016-04-26 10:09:08.830673	web_js		1500	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2016-04-26 10:09:08.659798	web_php		1500	ERR	socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2371
2016-04-26 10:09:07.753250	zmdc		1196	INF	'zmc -m 4' crashed, signal 10	zmdc.pl
2016-04-26 10:09:07.094180	zmdc		1196	INF	'zmc -m 4' starting at 16/04/26 10:09:07, pid = 1915	zmdc.pl
2016-04-26 10:09:07.085770	zmdc		1915	INF	'zmc -m 4' started at 16/04/26 10:09:07	zmdc.pl
2016-04-26 10:09:01.035500	zmwatch		1327	INF	Restarting capture daemon for CameraTest, shared data not valid	zmwatch.pl
2016-04-26 10:09:01.007320	zmwatch		1327	ERR	Memory map file '/dev/shm/zm.mmap.4' does not exist. zmc might not be running.	zmwatch.pl
2016-04-26 10:08:56.439842	web_js		1251	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2016-04-26 10:08:56.159543	web_php		1251	ERR	socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2371
2016-04-26 10:08:51.229550	zmdc		1196	INF	'zmc -m 4' crashed, signal 10	zmdc.pl
2016-04-26 10:08:50.886580	zmdc		1876	INF	'zmc -m 4' started at 16/04/26 10:08:50	zmdc.pl
2016-04-26 10:08:50.880900	zmdc		1196	INF	'zmc -m 4' starting at 16/04/26 10:08:50, pid = 1876	zmdc.pl
2016-04-26 10:08:45.502320	zmwatch		1327	INF	Restarting capture daemon for CameraTest, shared data not valid	zmwatch.pl
2016-04-26 10:08:45.474620	zmwatch		1327	ERR	Memory map file '/dev/shm/zm.mmap.4' does not exist. zmc might not be running.	zmwatch.pl
2016-04-26 10:08:43.972013	web_js		744	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2016-04-26 10:08:43.773241	web_php		744	ERR	socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2371
2016-04-26 10:08:35.973270	zmdc		1196	INF	'zmc -m 4' crashed, signal 10	zmdc.pl
2016-04-26 10:08:35.235160	zmdc		1196	INF	'zmc -m 4' starting at 16/04/26 10:08:35, pid = 1865	zmdc.pl
2016-04-26 10:08:35.217520	zmdc		1865	INF	'zmc -m 4' started at 16/04/26 10:08:35	zmdc.pl
2016-04-26 10:08:31.847467	web_js		744	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2016-04-26 10:08:31.590652	web_php		744	ERR	socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2371
2016-04-26 10:08:30.890690	zmwatch		1327	INF	Restarting capture daemon for CameraTest, shared data not valid	zmwatch.pl
2016-04-26 10:08:30.873400	zmwatch		1327	ERR	Memory map file '/dev/shm/zm.mmap.4' does not exist. zmc might not be running.	zmwatch.pl
2016-04-26 10:08:21.099650	zmdc		1196	INF	'zmc -m 4' crashed, signal 10	zmdc.pl
2016-04-26 10:08:20.775240	zmdc		1858	INF	'zmc -m 4' started at 16/04/26 10:08:20	zmdc.pl
2016-04-26 10:08:20.752310	zmdc		1196	INF	'zmc -m 4' starting at 16/04/26 10:08:20, pid = 1858	zmdc.pl
2016-04-26 10:08:19.725886	web_js		1498	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2016-04-26 10:08:19.403330	web_php		1498	ERR	socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2371
2016-04-26 10:08:14.403910	zmwatch		1327	INF	Restarting capture daemon for CameraTest, shared data not valid	zmwatch.pl
2016-04-26 10:08:14.377330	zmwatch		1327	ERR	Memory map file '/dev/shm/zm.mmap.4' does not exist. zmc might not be running.	zmwatch.pl
2016-04-26 10:08:07.201418	web_js		744	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2016-04-26 10:08:07.036557	web_php		744	ERR	socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2371
2016-04-26 10:08:04.823760	zmdc		1196	INF	'zmc -m 4' crashed, signal 10	zmdc.pl
2016-04-26 10:08:04.155590	zmdc		1850	INF	'zmc -m 4' started at 16/04/26 10:08:04	zmdc.pl
2016-04-26 10:08:04.137730	zmdc		1196	INF	'zmc -m 4' starting at 16/04/26 10:08:04, pid = 1850	zmdc.pl
2016-04-26 10:07:59.796000	zmwatch		1327	INF	Restarting capture daemon for CameraTest, shared data not valid	zmwatch.pl
2016-04-26 10:07:59.777710	zmwatch		1327	ERR	Memory map file '/dev/shm/zm.mmap.4' does not exist. zmc might not be running.	zmwatch.pl
2016-04-26 10:07:55.007046	web_js		1574	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2016-04-26 10:07:54.733688	web_php		1574	ERR	socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2371
2016-04-26 10:07:49.994520	zmdc		1196	INF	'zmc -m 4' crashed, signal 10	zmdc.pl
2016-04-26 10:07:49.660890	zmdc		1845	INF	'zmc -m 4' started at 16/04/26 10:07:49	zmdc.pl
2016-04-26 10:07:49.647320	zmdc		1196	INF	'zmc -m 4' starting at 16/04/26 10:07:49, pid = 1845	zmdc.pl
2016-04-26 10:07:43.977020	zmwatch		1327	INF	Restarting capture daemon for CameraTest, shared data not valid	zmwatch.pl
2016-04-26 10:07:43.957370	zmwatch		1327	ERR	Memory map file '/dev/shm/zm.mmap.4' does not exist. zmc might not be running.	zmwatch.pl
2016-04-26 10:07:42.611052	web_js		745	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2016-04-26 10:07:42.278260	web_php		745	ERR	socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2371
2016-04-26 10:07:34.404290	zmdc		1196	INF	'zmc -m 4' crashed, signal 10	zmdc.pl
2016-04-26 10:07:33.733970	zmdc		1841	INF	'zmc -m 4' started at 16/04/26 10:07:33	zmdc.pl
2016-04-26 10:07:33.725560	zmdc		1196	INF	'zmc -m 4' starting at 16/04/26 10:07:33, pid = 1841	zmdc.pl
2016-04-26 10:07:30.346789	web_js		745	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2016-04-26 10:07:30.086706	web_php		745	ERR	socket_sendto( /var/run/zm/zms-740725s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	23
markusonfire
Re: Having issues viewing streamed video. crash signal 10 in log
Bump - Can anyone help out with this?
are you sure the capture height and width are spot on? They must match from the config to the camera setting.
also try:
Remote Host Name: admin:ThePassword@192.168.0.52
Remote Host Path: /videostream.cgi
philip_d
Post by philip_d »
Try to use the below settings;
Source Path : rtsp://Username:password@ipaddress:port/
Remote Method : RTP/Multicast
Do you have enough ram? the mmap files go in /dev/shm which is often a ramdisk... and width the default buffers, etc you can chew up a fair amount of mem very quickly. Try reducing buffers to the minimum which Is 10 an set the pre-event frames and post event frames to 0 or 1.
