1.29.0 feed delay...?
McFuzz
Post by McFuzz » Mon Mar 28, 2016 12:22 am
I have a 5 camera setup - 4 are wired and one is wireless. Three of the cameras record on motion, one (wired) records on trigger only (from any of the three that record on motion) and the wireless one is simply a baby monitor.
I discovered that one of my record-on-motion cameras has had its feed delayed by nearly 10 seconds. Viewing it on the cameras own interface shows perfect sync but not through ZoneMinder (though alerts were recorded properly). Had to reboot the ZM box before it synced properly.
Any ideas or is this something to just live with?
Re: 1.29.0 feed delay...?
Post by knight-of-ni » Mon Mar 28, 2016 5:16 pm
Did you place a value in either of the MAX FPS fields?
McFuzz
Post by McFuzz » Mon Mar 28, 2016 7:01 pm
Yes I did - but they are identical to across all my motion-recording cameras.
Post by knight-of-ni » Mon Mar 28, 2016 7:10 pm
Is the value in the MAX FPS field equal to or less than the fps coming from the camera?
If yes, then there is your answer. You are describing the very symptom why we put a big red CAUTION note indicating you should read the help text.
McFuzz
Post by McFuzz » Mon Mar 28, 2016 7:20 pm
Hrm - I think I know what's going on. The MAX FPS is not more during the day, but during the night, when IR kicks in, the actual FPS gets halved...
Anyway to combat that?
Post by knight-of-ni » Mon Mar 28, 2016 7:39 pm
Those fields do not work for ip streams the way you want them to. That is why we put the warning there.
The simplest thing to do would be to put a value in there that is higher than the camera's frame rate, at any time of the day. The only reason to do this is to keep your cpu from jumping to 100% if one of the cameras falls off the network. If this has not been an issue for your system/network, then you should leave these fields empty.
McFuzz
Post by McFuzz » Mon Mar 28, 2016 8:10 pm
Ahhh - ok; I'll put them at 0 and double check on stuff but it shouldn't be a problem. These cameras are pretty solid.
Post by knight-of-ni » Mon Mar 28, 2016 8:17 pm
I would leave them empty, rather than put a zero in there. Not sure if it makes a difference, but if it just happens that it does make a difference, it won't be good.
