libvlc on zoneminder 1.28.1 on ubuntu server 14.04
AnotherBrian
Post by AnotherBrian »
In 1.28.0 the following was required
apt-get install libvlc-dev libvlccore-dev vlc
a2enconf zoneminder
adduser www-data video
There is no mention of it in 1.28.1. Is it an over-site?
I get the following log entires hinting something may be missing with libvlc:
2015-10-28 18:52:00.511130	zmdc	11013	ERR	'zmc -m 1' exited abnormally, exit status 255	zmdc.pl
2015-10-28 18:52:00.450314	zmc_m1	11302	FAT	Unable to create libvlc instance due to: (null)	zm_libvlc_camera.cpp	170
2015-10-28 18:52:00.392968	zmc_m1	11302	INF	Priming capture from rtsp://admin:12345@192.168.2.70//Streaming/Channels/1?tcp	zm_libvlc_camera.cpp	145
2015-10-28 18:52:00.339479	zmc_m1	11302	INF	Starting Capture	zmc.cpp	195
2015-10-28 18:52:00.128980	zmdc	11013	INF	'zmc -m 1' starting at 15/10/28 18:52:00, pid = 11302	zmdc.pl
2015-10-28 18:52:00.128980	zmdc	11302	INF	'zmc -m 1' started at 15/10/28 18:52:00	zmdc.pl
2015-10-28 18:52:00.055060	zmdc	11013	INF	Starting pending process, zmc -m 1	zmdc.pl
I'm open to going to 15.10 but there I ran into the vlc segment fault problem that is currently unresolved.
Re: libvlc on zoneminder 1.28.1 on ubuntu server 14.04
libvlc may not work for you. I used to have the addition of some other vlc libraries but did not put them into the most recent how-to. I recommend using ffmpeg as it will work much more reliably than libvlc.
You may need to install "extra" VLC components
I have not had issues you mentioned with 15.10. But I did not try libvlc. Same recommendation as above: use ffmpeg!
AnotherBrian
Isn't vlc in the following the graphical program vlc and therefore unneeded on a server version of zoneminder?
AnotherBrian
Found an old drive that had ubuntu 14.04.1 running v1.28.0 and avoided doing upgrade or update. Works greats!
gnocera
Post by gnocera »
Hello, stick to ffmpeg.
We also tried some time with libvlc but we notice strange behaviors.
So we got back to ffmpeg and all works fine.
Regards,
Giuseppe
AnotherBrian
whichi ffmpeg? looks like its a mess in terms of forks and conflicts. Perhaps this is why old workings stuff stopped working.
http://stackoverflow.com/questions/9477 ... and-avconv
