viewing multiple cams from multiple servers
Brushpopper
Post by Brushpopper » Wed Oct 07, 2015 1:22 am
Ok, guys, maybe I am little convoluted here but I am running 2 zm servers, my main one is using ubuntu 12.o4 with ZM 1.28.1 and 6 cameras, all of them ps3 eye cameras... my secondary server is running ubuntu 14.04 with ZM 1.28.2 and 4 cameras (with hopes of adding a couple more) and these are a mixture of ps3 eye and ps2 eyetoy cameras.
On my main server, I have an external monitor (36" flat screen tv) that I use basically as a cctv setup, and I am racking my brain trying to include the 4 cams from my secondary server onto the one web gui. I have tried several options when adding a remote camera, and none of them are working, below are my inputs
on the source tab for
remote host name, I have tried just the local ip address and I have also tried the username:password@IP address
for remote host path I have tried both of the options below
/cgi-bin/nph-zms?mode=jpeg&monitor=<MONITOR_ID_HERE>=watch&mid=1&scale=100&maxfps=5&buffer=0 .... (I may not be using the correct monitor id???)
or
/cgi-bin/nph-zms?mode=jpeg&monitor=<MONITOR_ID_HERE>&scale=100&maxfps=10&buffer=1000&user=<USERNAME>&pass=<PASSWORD>
none of these are working, help me pleeeease.
Re: viewing multiple cams from multiple servers
Post by bbunge » Wed Oct 07, 2015 2:16 am
Here is the html code I use on a web page:
<img src="http://server-ip/cgi-bin/nph-zms?mode=j ... &pass=user">
I have a non-privilage user that can only view the monitors
You should be able to use the remote method with http and the video source of:
/cgi-bin/nph-zms?mode=jpeg&monitor=12&scale=130&maxfps=5&buffer=1000&user=user&pass=user
In the above change monitor= to your monitor number. Scale= may not be needed for you. If you do not log in omit user= and pass=
Brushpopper
Post by Brushpopper » Wed Oct 07, 2015 2:28 am
thanks bbunge, got it to work to view the single camera, but it still does not show up in montage with the others...... hmmmm one step closer tho
Brushpopper
Post by Brushpopper » Wed Oct 07, 2015 3:12 am
My bad.... rebooted the main server and everything is working perfectly now... thanks so much for all your help
Users browsing this forum: No registered users and 8 guests
