Set function from API does not work
marcolino7
Re: Set function from API does not work
Post by marcolino7 »
Hi asker,
sorry for less information provided, but meanwhile I did some other test, and rebooted all server, Zoneminder and Openhab.
After reboot, seems API working from both, browser and curl.
I did more test this evening, and I'll keep you updated.
Regards
Marco
Production Zoneminder 1.31.4 Ubuntu 16.04 LTS on VmWare ESXi
6 Cameras FOSCAM FI8918W
OpenHab Integration
marcolino7
Hi asker,
all working fine now. I have last version of ZM and API, authentication works, and I can control my ZM from OpenHab.
Now I'm back on original issue, the funcion does not work due a bug in MonitorsController.php.
Here is my version of the file, can you help me to add daemon controller?
<?php
App::uses('AppController', 'Controller');
 * Monitors Controller
 * @property Monitor $Monitor
 * @property PaginatorComponent $Paginator
class MonitorsController extends AppController {
 * Components
 * @var array
	public $components = array('Paginator', 'RequestHandler');
 * index method
 * @return void
	public function index() {
                $this->Monitor->recursive = 0;
        	$monitors = $this->Monitor->find('all');
        	$this->set(array(
        	    'monitors' => $monitors,
        	    '_serialize' => array('monitors')
 * view method
 * @throws NotFoundException
 * @param string $id
 * @return void
	public function view($id = null) {
		if (!$this->Monitor->exists($id)) {
			throw new NotFoundException(__('Invalid monitor'));
		$options = array('conditions' => array('Monitor.' . $this->Monitor->primaryKey => $id));
		$monitor = $this->Monitor->find('first', $options);
		$this->set(array(
			'monitor' => $monitor,
			'_serialize' => array('monitor')
 * add method
 * @return void
	public function add() {
		if ($this->request->is('post')) {
			$this->Monitor->create();
			if ($this->Monitor->save($this->request->data)) {
				$this->daemonControl($this->Monitor->id, 'start', $this->request->data);
				return $this->flash(__('The monitor has been saved.'), array('action' => 'index'));
 * edit method
 * @param string $id
 * @return void
	public function edit($id = null) {
		$this->Monitor->id = $id;
			$message = 'Saved';
		} else {
			$message = 'Error';
		$this->set(array(
			'message' => $message,
			'_serialize' => array('message')
 * delete method
 * @param string $id
 * @return void
	public function delete($id = null) {
		if (!$this->Monitor->exists()) {
		$this->request->allowMethod('post', 'delete');
		$this->daemonControl($this->Monitor->id, 'stop');
		if ($this->Monitor->delete()) {
			return $this->flash(__('The monitor has been deleted.'), array('action' => 'index'));
		} else {
			return $this->flash(__('The monitor could not be deleted. Please, try again.'), array('action' => 'index'));
	public function sourceTypes() {
		$sourceTypes = $this->Monitor->query("describe Monitors Type;");
		preg_match('/^enum\((.*)\)$/', $sourceTypes[0]['COLUMNS']['Type'], $matches);
		foreach( explode(',', $matches[1]) as $value ) {
			$enum[] = trim( $value, "'" );
		$this->set(array(
			'sourceTypes' => $enum,
			'_serialize' => array('sourceTypes')
	// Check if a daemon is running for the monitor id
	public function daemonStatus() {
		$id = $this->request->params['named']['id'];
		$daemon = $this->request->params['named']['daemon'];
		$monitor = $this->Monitor->find('first', array(
			'fields' => array('Id', 'Type', 'Device'),
			'conditions' => array('Id' => $id)
		// Clean up the returned array
		$monitor = Set::extract('/Monitor/.', $monitor);
		// Pass -d for local, otherwise -m
		if ($monitor[0]['Type'] == 'Local') {
			$args = "-d ". $monitor[0]['Device'];
		} else {
			$args = "-m ". $monitor[0]['Id'];
		// Build the command, and execute it
		$zm_path_bin = Configure::read('ZM_PATH_BIN');
		$command = escapeshellcmd("$zm_path_bin/zmdc.pl status $daemon $args");
		$status = exec( $command );
		// If 'not' is present, the daemon is not running, so return false
		// https://github.com/ZoneMinder/ZoneMinder/issues/799#issuecomment-108996075
		// Also sending back the status text so we can check if the monitor is in pending
		// state which means there may be an error
		$statustext = $status;
		$status = (strpos($status, 'not')) ? false : true;
		$this->set(array(
			'status' => $status,
			'statustext' => $statustext,
			'_serialize' => array('status','statustext'),
	public function daemonControl($id, $command, $monitor=null, $daemon=null) {
		$args = '';
		$daemons = array();
		if (!$monitor) {
			// Need to see if it is local or remote
				'fields' => array('Type', 'Function'),
			$monitor = $monitor['Monitor'];
		if ($monitor['Type'] == 'Local') {
			$args = "-d " . $monitor['Device'];
		} else {
			$args = "-m " . $id;
		if ($monitor['Function'] == 'Monitor') {
			array_push($daemons, 'zmc');
		} else {
			array_push($daemons, 'zmc', 'zma');
		foreach ($daemons as $daemon) {
			$shellcmd = escapeshellcmd("$zm_path_bin/zmdc.pl $command $daemon $args");
			$status = exec( $shellcmd );
OpenHab Integration
marcolino7
Hi @asker,
finally it seems I have fixed. Let me know if my code is fine and Can you add this to ZM code? may I have to open an issue on git?
			$message = 'Saved';
		} else {
			$message = 'Error';
		$this->set(array(
		//I added Line Below
		$this->daemonControl($this->Monitor->id, 'restart');
OpenHab Integration
marcolino7
Hi @asker,
unfornunately my code does not work.
When I setup Function to "Monitor" via API, the monitor still continue to record on motion.
Please let me know what you need to troubleshoot.
Regards
OpenHab Integration
asker
Post by asker »
Please change your line to
$this->daemonControl($this->Monitor->id, 'restart', $this->request->data);
I tested and it works - just refresh your web console and you will see the monitor has been updated. If you monitor your logs you will also see that your monitor restarts correctly.
marcolino7 wrote:Hi @asker,
Regards
Please read before posting:
ES docs
zmNinja docs
marcolino7
I got something like that:
2015-09-28 17:41:58.143934	zma_m1	9960	INF	In mode 2/0, warming up	zma.cpp	142
2015-09-28 17:41:58.083790	zmdc	9960	INF	'zma -m 1' started at 15/09/28 17:41:58	zmdc.pl
2015-09-28 17:41:58.083780	zmdc	1186	INF	'zma -m 1' starting at 15/09/28 17:41:58, pid = 9960	zmdc.pl
2015-09-28 17:41:58.078040	zmdc	1186	INF	Starting pending process, zma -m 1	zmdc.pl
2015-09-28 17:41:58.012956	zmc_m1	9959	INF	Starting Capture version 1.28.106	zmc.cpp	250
2015-09-28 17:41:57.965330	zmdc	1186	INF	'zma -m 1' exited normally	zmdc.pl
2015-09-28 17:41:57.948209	zma_m1	9602	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2015-09-28 17:41:57.943270	zmdc	1186	INF	'zma -m 1' sending stop to pid 9602 at 15/09/28 17:41:57	zmdc.pl
2015-09-28 17:41:57.908340	zmdc	9959	INF	'zmc -m 1' started at 15/09/28 17:41:57	zmdc.pl
2015-09-28 17:41:57.908310	zmdc	1186	INF	'zmc -m 1' starting at 15/09/28 17:41:57, pid = 9959	zmdc.pl
2015-09-28 17:41:57.900420	zmdc	1186	INF	Starting pending process, zmc -m 1	zmdc.pl
2015-09-28 17:41:57.810104	zma_m2	9954	INF	In mode 2/0, warming up	zma.cpp	142
2015-09-28 17:41:57.788180	zmdc	1186	INF	'zmc -m 1' exited normally	zmdc.pl
it seems a restart of daemon for monitor with id 1.
I'll keep under monitor.
Marco
OpenHab Integration
