Hey all I'm new here
I've recently installed Zoneminder 1.28.1 on Centos 6.6 64 bit on a virtual machine and I'm getting this problem that seems to be filling up my hard drive with bogus events at an insanely fast rate.
This is an example of it (I uploaded to imgur but this forum won't let me link it properly) and it seems to happen every 2-5 seconds imgur(.)com/Fz5gx2r.jpg
The camera I'm using is a Hikvision DS-2CD2032-I and on it's own web interface this never happens.
Any help would be appreciated thank you.
Recording Problems
Recording Problems
Re: Recording Problems
Is your source type ffmpeg?
attila123 wrote:Hey all I'm new here
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
Yes it is.asker wrote:Is your source type ffmpeg?
Try the native rtsp option or other strategies
http://www.zoneminder.com/wiki/index.ph ... SP_streams
attila123 wrote:Yes it is.asker wrote:Is your source type ffmpeg?
ES docs
zmNinja docs
ES docs
zmNinja docs
Okay so I've tried every single other option and I just get blank screens with Remote and VLC, only setting that works is the ffmpeg and RTP/RTSP link. I have set the maximum frames to way higher than the camera can actually do and I think that has done the trick, I will test it out for about an hour and report back on any smudging events.
Edit: Yup increasing the fps seems to have done the trick, I set it to 40 fps while the camera is running at 3 mp 20 fps.
The Maximum FPS in the ZM Monitor setup is for local cameras. Value should be (blank) for everything else.
bb
bb
Actually, it should be set to a value higher than the FPS of your in-camera setting. If you don't and your camera goes offline, ZM eats up all the CPU.bbunge wrote:The Maximum FPS in the ZM Monitor setup is for local cameras. Value should be (blank) for everything else.
bb
ES docs
zmNinja docs
ES docs
zmNinja docs
