JPEGs with Firefox
8ace
JPEGs with Firefox
Post by 8ace »
Hi, when I do a montage, sometimes I get 'broken' jpeg icons, or it just sits there trying to load the jpeg...
I've read some of the previous posts but didn't see a clear fix for the jpeg issue (I don't have a need for MPEG - prefer to use firefox without add-ins) - - is there a workaround for this without having to using mpeg?
thanks, everyone.
Ruler
Post by Ruler »
Do a search for about:config - there are a few options in firefox that relate to the number of streams that can be active at once that you need to change. Might want to make a separate profile for video monitoring though, as I noticed the changes make certain web sites load slowly while not affecting others. (Newegg was horrible taking over 10 minutes to load the main page while staples loaded the same as before in a matter of a few seconds.)
cordel
Post by cordel »
8ace
Post by 8ace »
Thanks, I'll go give it a try! :)
8ace
Post by 8ace »
The broken JPEG fix to Firefox (by changing the browser.cache.check_doc_frequency and
browser.cache.disk.enable) worked a treat!
Thanks - case closed!
cordel
Post by cordel »
:D
Have fun.
Regards,
Cordel
8ace
Post by 8ace »
... after a few days my broken images are back again!
I've checked the settings (per the link above) but nothing's changed, so I'm out of ideas ... anyone :?
cordel
Post by cordel »
In the options under the tools tab you can check the ZM_RAND_STREAM option.
If that don't do it try this thread:
http://www.zoneminder.com/forums/viewto ... cfrequency
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
