Hi all,
Its been awhile.
Apparently my Zoneminder installation webinterface is not letting me in. I checked the ZM database to verify I was using the correct password I had setup and even reset up the admin password to make sure.
Its just getting stuck at the login screen. Can I disable security via CLI?
Thanks in advance
Can I disable web interface security from CLI?
- Contact:
Re: Can I disable web interface security from CLI?
Add:
to your zm.conf and restart zoneminder, should do the trick. If that fails you can change the value of ZM_OPT_USE_AUTH in the mySQL "Config" table to a "0". However, I just tested overriding it in zm.conf on one of my servers and it worked so that should be all you need. Just be sure to remove the option from the config if you want to re-enable auth.
ZM_OPT_USE_AUTH=0
Thank you so much. That worked for me perfectly!!! I was worried for a minute there!!!linuxsense wrote:Add:
to your zm.conf and restart zoneminder, should do the trick. If that fails you can change the value of ZM_OPT_USE_AUTH in the mySQL "Config" table to a "0". However, I just tested overriding it in zm.conf on one of my servers and it worked so that should be all you need. Just be sure to remove the option from the config if you want to re-enable auth.Code: Select all
ZM_OPT_USE_AUTH=0
