Compile with libvlc issues
chaoticmachinery
Post by chaoticmachinery »
I am trying to compile 1.27 and use the VLC libraries. Whenever I run the ./configure I keep getting the following message:
checking for libvlc_new in -lvlc... no
configure: WARNING: libvlc.a may be required for streaming
I download and compiled the latest version of VLC. Currently it is install in /usr/local.
Any pointers on getting this to work would be appreciated.
Thanks,
CM
windracer
Re: Compile with libvlc issues
Post by windracer »
Have you tried using the new cmake instructions instead? I just did this last week (recompiled for vlc support) and had no issues. Details are in the INSTALL file.
