Camera Settings for D-link DCS942L
I finally got zoneminder service running, now I'm trying to get the camera to run. The camera, D-link DCS943L is listed on the Hardware page with only 2 settings:
Source Type: ffmpeg
Source Path: rtsp://<camera ip>:554/play2.sdp
The source path I'm using is rtsp://198.168.000.007:554/play2.sdp
I have the camera hooked directly to my router, and the ip in the source path is the ip of the camera in the router. Is that the intended set up to go with these settings? I'm confused because the path includes an ip address but the source type is not network.
The word monitor is a link and I can click on it to and I can see little blue and red boxes, but no images.
Function is set to "monitor".
I know the camera works because I can hook it up to my windows computer.
When I click on probe from the localhost webpage, it doesn't detect the camera.
What else can I check?
I'm also confused about the device path.
I have some kind of thing, which is neither a file or a directory at /dev/video0 but when I try to read it with
zmu -d video0 -q -v
it says: failed to query crop capabilities video0 : success
Source Type: ffmpeg
zmu -d video0 -q -v
Re: Camera Settings for D-link DCS943L
I'm still trying to get my camera settings.
The documentation says:
run zmu -d <device_path> -q -v to get a dump of the settings (note, you will have to additionally supply a username and password to zmu if you are running in authenticated mode). You can then enter these values into the video related options of the monitor configuration panel. The '<device_path>' referred to here is the path to your video device file, for instance /dev/video0 etc. If 'zmu' gives you an error related to permissions run zmfix -a to make sure you can access all the video devices.
How do I find out where my video device file is? I do have /dev/video0 but I also have /dev/video1
Is there something I have to do to set that file up with my camera or does it just come with the operating system?
What is meant by "authenticated mode"? Is that referring to the username/password of the camera?
I'm beginning to suspect that the camera settings are not the whole problem.
On localhost/zm/index.php is a link to "log" which leads to localhost/zm/index.php?view=log which shows other assorted problems.
I'll start a new thread if I need help with those.
Can't answer your problem, but :-rodeored wrote:The camera, D-link DCS943L ... ip address ...
zmu -d video0 -q -v
/dev/video0 is a local capture card (analogue, digital TV, USB stick tuner maybe or something similar) and is nothing to do with your IP Camera. IP cameras never (?) show up as /dev/anything.
Don't get confused trying to chase problems with an irrelevant bit of hardware!
??? There is no source type of network. You have local, remote, ffmpeg, vlc, and curl. Last three are all network variations.rodeored wrote:I finally got zoneminder service running, now I'm trying to get the camera to run. The camera, D-link DCS943L is listed on the Hardware page with only 2 settings:
Source Type: ffmpeg
That tells you that the camera isn't broken, but that doesn't mean your settings are right, either.I know the camera works because I can hook it up to my windows computer.
Fastest debug step you can do is to try the stream through vlc on your windows box. If it works there, then you should be able to get it working in zm no problem. If it doesn't, then don't bother.
mikb wrote:
Well then when the documentation says/dev/video0 is a local capture card (analogue, digital TV, USB stick tuner maybe or something similar) and is nothing to do with your IP Camera. IP cameras never (?) show up as /dev/anything.
How do I know which, if any device file my camera is attached to? I never entered any code to attach it to any particular device file and I don't see any instructions anywhere for doing that.Enter the full path to the device file that your camera is attached to, e.g. /dev/video0.
TheKorn wrote:
I also tried to create a video stream with:
Source Type:remote
Remote Protocol: HTTP
Remote Host Name: username:password@198.168.000.007
Yes I meant remote??? There is no source type of network. You have local, remote, ffmpeg, vlc, and curl. Last three are all network variations.
Source Type:remote
I was not able to get it working in VLC. However, the camera is listed on the Zoneminder hardware page, so it must be something I'm not doing correctly. I'm trying to figure out the VLC error messages.Fastest debug step you can do is to try the stream through vlc on your windows box. If it works there, then you should be able to get it working in zm no problem. If it doesn't, then don't bother.
It's an IP camera. It isn't any kind of "device". That's for hardware physically attached to the computer, either PCI/PCI-E, possibly USB.rodeored wrote: Well then when the documentation saysHow do I know which, if any device file my camera is attached to? I never entered any code to attach it to any particular device file and I don't see any instructions anywhere for doing that.Enter the full path to the device file that your camera is attached to, e.g. /dev/video0.
A remote camera feed from a webcam half way round the world won't be /dev/anything. You need to make an IP connection to it, so the important facts will be an IP address, a port number (maybe), a URL, a path, maybe username/password, the usual webby/internetty things.
You have it working in other players, so start from there. Just because your IP camera is local to you doesn't make it any different from using an IP camera miles away. IP is IP, and is dealt with through the networking side of linux.
I don't know what line in the docs you are quoting above, but you're in the area that deals with local physical capture cards etc. Step away from that, it will only confuse things
I don't use RTSP net links, so can't advise further on that (only motion jpeg, streaming by http://)
For your usage, I'd pretend that camera type remote doesn't exist. I'm sure there is something that it's good at, but I certainly haven't found what! I'd use either ffmpeg or vlc, exclusively.rodeored wrote: Yes I meant remote
Can't fetch a rtsp stream using http. (Can't pour milk into a hammer - just not compatible!)Source Type:remote
Reason why I suggested vlc is because it's a lot faster to try lots of configs via vlc than zoneminder. It's not that you can't go directly to zoneminder, it's just that for newbies it's usually easier.I was not able to get it working in VLC. However, the camera is listed on the Zoneminder hardware page, so it must be something I'm not doing correctly. I'm trying to figure out the VLC error messages.
That was underrodeored wrote:mikb wrote:Well then when the documentation says/dev/video0 is a local capture card (analogue, digital TV, USB stick tuner maybe or something similar) and is nothing to do with your IP Camera. IP cameras never (?) show up as /dev/anything.How do I know which, if any device file my camera is attached to? I never entered any code to attach it to any particular device file and I don't see any instructions anywhere for doing that.Enter the full path to the device file that your camera is attached to, e.g. /dev/video0.
IP cameras, by definition, are never local devices. Local means (for these purposes) "directly plugged into". It is not directly plugged into your computer, so not local.Source Tab (local device)
Thanks for the clarification.
In vlc, if I add http as the destination, it wants a path. I have no idea what to put in there. I asked in the videolan group but no one has answered.
I'm probably just doing it completely wrong. I have no idea where to start to see the camera image in VLC. When I look at "open capture device, there's nothing there.
I don't have your camera (don't know where you saw it was supported in ZM, btw). But I do have other cameras that do rtsp streaming.
In VLC, I go to media, open network stream. Then I put in
Judging by the info in the wiki, I'd say you should probably put in
rtsp://(ip address of camera)/play2.sdp
rtsp://(ip address of camera):554/play2.sdp
Re: Camera Settings for D-link DCS942L
Doesn't the fact that its listed on this page mean its supported?
(I just noticed that the thread subject says Camera Settings for D-link DCS943L which is wrong. the camera is
D-link DCS942L
http://www.zoneminder.com/wiki/index.php/D-Link
I tried :554/play2.sdp and /play2.sdp with and without authentication,
all four times it comes up with
live555 error: SETUP of'audio/PCMU' failed RTSP response was truncated. Increase "RTSPClient::responseBufferSize"
live555 error: no data received in 10s, aborting
D-link DCS942L
