I am running Zoneminder 1.26.5 on Ubuntu Server 13.10 x64. My server has dual 10/100/1000 NICs. I also use the server as a NAS with 12TB of storage. I am able to specify which NIC my NAS traffic runs on, but is there a way to specify which NIC my zoneminder traffic runs on? It seems to randomly switch NICs back and forth.
Edit:
Sorry, I should add that I am using Foscam IP cameras.
Dual NIC, specify which NIC zoneminder uses?
Re: Dual NIC, specify which NIC zoneminder uses?
Nobody has any information on this?
Sounds more like a basic networking problem/question than a Zoneminder specific thing. When you say you have 2 NICs, unless you are doing something very clever, they will have different IP addresses, most likely in different subnets, and your routing table will work out (by the magic of networking) where to send the packets. You shouldn't have to be telling things what's on what NIC. If you are doing things like bonding multiple network cards together, load balancing, and advanced stuff, then that's outside my practical knowledge!Francopacks wrote:Nobody as any information on this?
Can you explain more about how you (think you) have your network configured?
And, what happens when you (as root) type
ifconfig
route
ifconfig
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:266 errors:0 dropped:0 overruns:0 frame:0
TX packets:266 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:21821 (21.8 KB) TX bytes:21821 (21.8 KB)
p5p1 Link encap:Ethernet HWaddr 00:30:48:dc:d4:a6
inet addr:192.168.1.125 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::230:48ff:fedc:d4a6/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:29788 errors:0 dropped:0 overruns:0 frame:0
TX packets:963 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:3732724 (3.7 MB) TX bytes:101194 (101.1 KB)
Interrupt:16 Memory:e0400000-e0420000
p6p1 Link encap:Ethernet HWaddr 00:30:48:dc:d4:a7
inet addr:192.168.1.119 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::230:48ff:fedc:d4a7/64 Scope:Link
RX packets:29554666 errors:0 dropped:0 overruns:0 frame:0
TX packets:14414097 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:42111873020 (42.1 GB) TX bytes:1207785600 (1.2 GB)
Interrupt:17 Memory:e0500000-e0520000
route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default Ball3 0.0.0.0 UG 0 0 0 p6p1
link-local * 255.255.0.0 U 1000 0 0 p5p1
192.168.1.0 * 255.255.255.0 U 0 0 0 p6p1
192.168.1.0 * 255.255.255.0 U 0 0 0 p5p1
/etc/network/interfaces
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
auto p5p1
iface p5p1 inet dhcp
# The seconadry network interface
auto p6p1
iface p6p1 inet dhcp
Both ports are in the same network then, no separate subnets, all your machines/cameras are in 192.168.1.X ...Francopacks wrote:Code: Select all
p5p1 inet addr:192.168.1.125 Bcast:192.168.1.255 Mask:255.255.255.0 p6p1 inet addr:192.168.1.119 Bcast:192.168.1.255 Mask:255.255.255.0
Is that not what you intended?
What is the intention of having two network ports on one machine (usually, it's to connect to two different networks e.g. router/bridge/firewall. Otherwise, for redundancy and bonding for extra speed)
I assume (dangerous) that both ports are plugged into a common switch, so are effectively working in parallel?
They are plugged into two different switches, just on the same vlan (with the same domain controller giving out dhcp addresses). My intention is to have file server traffic not be affected by the bandwidth required for the IP cameras. Maybe bonding the ports would be a better idea like you suggested.
You can define listening interface for applications... That would mean configuring Apache to listen on a specific interface. But you're asking about choosing which interface is used for SENDING. Zoneminder itself doesn't care what adapter you're using for sending traffic. You would need to configure routes that point to one of your NICs. You can either put individual IPs in your routing table for each of your cameras or clump them onto their own subnet. You should be able to do the same with your NAS traffic.
