cmake error
sgrobinson
cmake error
Post by sgrobinson »
I seem to be getting this problem recently when trying to build. I got ZM to automatically create the zm_conf.cmake file but I cant run sudo cmake -C zm_conf.cmake because of the below error. Any suggestions? :( Sorry - I have googled and this was a last resort asking!
http://pastebin.com/EtwY9e1H
mastertheknife
Re: cmake error
Post by mastertheknife »
It seems you are running cmake without specifying the source folder.
It should be like this (don't forget the period at the end):
cmake -C zm_conf.cmake .
After that, make and then sudo make install. You might also need to update the symlinks for the images/ and events/ folder because make install overrides them. zmlinkcontent.sh can help you with that. e.g. if your events folder is /zm/events and the images folder is /zm/images, you should run:
sudo ./zmlinkcontent.sh /zm"
Kfir Itzhak.
sgrobinson
Re: cmake error
There I was about to submit an update to the INSTALL file, but If I had actually read it properly there is a . at the end of that command.
Sorry - I did look there, promise!
